Smev grill/ oven combi
jonsey324
Bury st Edmunds, Suffolk.
Rapido V68
i'm a newbie
Good evening,
Just getting the last few bits done on my Rapido v68 pvc before this weekend away in Wales.
Just tested everything to make sure it all works, my smev grill/oven all works fine except when trying to increasing the temp from 1-6, the flame hardly changes, is this normal or should as I except the flames to increase slightly?
Thanks everyone.
kieran
oven will run on full until it reaches temperature then cut down to small flame, light it shut the door turn to number 1 and leave for a few minutes
Yep, that’s how they work.
Just replaced both burners in ours!
When lighting you have to keep button pressed for a few seconds, if you lift the door a little it will stop sparking!
