Smev 401. 401s Cooker Hobb and Grill (1 Viewer)
sonar
1,267
2,050
Smev 401. 401s Cooker Hobb and Grill.
I know it’s an old cooker. Fitted. 2003.
But the ignition is not lighting the gas. There is a spark but seems weak. Eventually I may get one ring lit.
is there anything I can try before I have to replace the ignition unit. That’s I can find one in stock.
Feb 21, 2016
4,922
29,741
Uk
Since 2017
Ours isn’t brilliant,sometimes it works well,other times not. We use one of those clicky gas lighter thingys that you can by for a couple of quid and lasts forever .
S
sonar
1,267
2,050
If I can’t find a solution I may do the same.
Thanks..
wasp
1,724
18,180
Warsop
None gone caravannin
Ave you tried taking the burner caps off and cleaning the igniter probes
busbuddy
1,297
2,922
leicestershire
swift suntor 630G
since 1994
Does it light better if something is on the ring, kettle/saucepan etc
S
sonar
1,267
2,050
Yes did that and made no difference. Even tried a new refilled gas bottle in case it was low gas pressure.
S
sonar
1,267
2,050
It does work on 12 volts .
thought that. And turned off the battery to the home part and got nothing .
Jan 8, 2013
8,494
11,532
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
It could be just misaligned or worn or covered in grease.
Move it closer to what ever it sparks onto and give it a clean
