SKY Q Box in Moho (1 Viewer)
Saint76
49
26
Southampton
8years
We currently have a Sky box in moho which works perfectly well threw the on roof Sat Dish ( This is a smaller multi room box with the Sky supplied viewing card).
We are thinking of changing to the SKY Q boxes in the house which are Wi Fi based ,although the aerial fitted to the outside of the house is still required for the Mothership Box
hard wired in Front room.
My understanding is that additional boxes as in a multi room set up can be added as they are Wi Fi controlled and are supplied with there own small Wi Fi unit which is plugged into the box this then allows one to move it from room to room.
Have any other Funsters done as i have with the older style box and then swopped to Sky Q and found the system will not work.
Have a Huawei 4g Wi Fi mobile box which works great ,all over Europe.
But am worried that i could end up paying a stupid amount of money to keep it topped up as i am now downloading hours of data.(Ok can maybe get around that with unlimited data package,at moment data package is adequate for are needs).
We currently have the Sky Sports package for the footie etc which works all around europe todate.
Hope this all makes sense as not clued up on tinternet type stuff now the offside rule and im your man.
ambulancekidd
Sep 23, 2014
10,371
28,397
Ayrshire Scotland
Swift Kon-Tiki 640
Since 1964 Gosh that makes me feel old.
Sadly Sky Q uses a different LNB & WI-FI together, so for now its a non starter.
D
Deleted member 29692
No you can’t and there's more to it than just internet connections.
Sky Q uses a different type of LNB - a wide band one. Your dish on the motorhome will have a standard LNB.
If it’s an auto dish and you change the LNB the controller probably won't work.
If it's a manual dish you could potentially change the LNB if you can find a wide band one that will fit.
If you can get past the LNB issue you need proper broadband internet to get anything more than basic functionality. A Mifi is simply not going to cope - 4G isn't fast enough and you won't have the bandwidth anyway.
If you change to Sky Q and put your old HD box in the van you then have viewing card issues - The Sky Q viewing card is different and won't work in an HD box. There's supposed to be a way of making it work involving pairing it via a website but it's a royal faff and I've never managed it.
I went through all this in some depth a couple of years ago when we got Sky Q at home. Eddie Vanbitz even contacted the manufacturers of my satellite kit to get their opinion.
The general consensus is that there's no practical way to do it.
If you really can't do without Sky in the van then the best way to get it is by using the SkyGo app. If you use it on a proper laptop you can connect to your TV, if you use a tablet or phone you can't.
D
Jackson Leisure in Wakefield says he can make Sky Q work for approx £600 you can always ask anyway.
Bill
You will definitely get a signal to the Sky Q box with a £30 replacement LNB. That’s never been in doubt.
The first problem is the chance that using the new LNB will damage the controller on an auto system. None of the manufacturers have tested it yet, I assume due to lack of demand, so they can’t and won’t say whether it will work or not. Trying it anyway would invalidate any warranty and most controllers are around £500 to replace so understandably nobody wants to risk it.
Secondly you only get the most basic of limited functionality without an internet connection. That’s a proper broadband connection, not a 4G one from a MiFi.
What’s he doing for £600 given that he isn’t going to be solving the second issue? Has he come up with a solution for the first issue that works on all systems and that the manufacturers have accepted for warranty purposes?
Sep 18, 2015
697
702
Selby, North Yorkshire
Rapido 8066DF
No idea how or what he does he fitted a new osyter 85 sat system and text me 12 months after asking if i wanted to update to Sky Q, i thought £600 was dear so i stuck with what i have.
Bill
Mr Chrysalis
2,367
317,848
Lincolnshire
Rapido 890F A Class
Since 2016, caravans before that, folding Caravan, tents before that
I’m going to stick with my multiroom Skyboxinthe Moho as long as I can. I have not seen any date when the old Sky system will be redundant. When it is I’ll dump Sky and go FreeSat with a decent sized hard disc recorder
eddie
8,157
41,271
Taunton Somerset
RV
since 1989
We have been able to convert an Oyster Vision III
You need to buy the Sky Q LNB from Sky and the older Vision III (Latest variant on offer is the Oyster Vision V)
It does work is a bit clunky and isn't worth the effort to be honest, and of course Sod's Law the very first one we did developed a gear box fault so all had to be returned to original to be able to return it under warranty to Oyster!
We decided then that we wouldn't bother doing any more lol
It was pretty disappointing without the broadband interaction anyway
Saint76
Saint76
49
26
Southampton
8years
Thank you every one for your advice will stick with my multi-room box in the van and carry on living the dream.
