Sink Taps loose (2 Viewers)
Sep 20, 2014
155
36
Luton
Coach built
8 years
I’m looking for some help and advice as to how I can tighten the dual tap on my kitchen sink
When we use it the base swivels as we are turning the water on
We have an Autosleeper Cotswold
Kind regards
43,337
49,540
Usually .... Reach up underneath and follow the pipes up to the tap.
There should be a large plastic nut which needs retightening.
It will need an open ended spanner and a bit of dexterity while holding the tap in position.
If the fridge etc is below the sink it may need removing first.
Others will be along if the fixing method is different on your tap.
Feb 2, 2015
2,284
7,264
Shropshire, UK
A motorhome!
we are still learning
Hi there. Is it like this one?
If so..It has a large nylon Nut holding it underneath behind the drawer . Its a bit of a bummer to get on with a wrench but it can be done . Take your time and don't over tighten. Just clamp it up . Im sure you will do it easily enough.
Kev
DuxDeluxe
14,659
72,818
Planet Zog
A woosh bang van
Had the same issue with the Le Voyageur a few weeks ago. Prepared for the worst, removed the giant drawer under the hob so I could reach it and ......... normal domestic mixer tap with the single nut on a long thread and a flat collar!! Quick tighten with box spanner and job done. The real sod was getting the giant drawer back on its runners awkward size and heavy
Mar 23, 2012
9,551
32,148
sleights
c class
Replaced the one in our washroom last year the nut had a slot in the end so could be done with a flat bladed screwdriver although more purchase with a box spanner. It its been lose a while I would take it off and check the workop for signs of water leaking around the base might be worth putting a bit of sealant down first
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
When I replaced the monoblock tap in ours I used a wrench like this.
https://www.screwfix.com/p/basin-wrench-11/14631
It is a standard component in my tool kit. Just check that it will open wide enough to fit the locking nut.
Most important - do not over tighten. Most motorhome taps are made of chromed plastic and it is easy to crack them if you apply too much force.
The rehctub
Sep 20, 2014
155
36
Luton
Coach built
8 years
Thank you all for such quick and helpful reply
Have had same request elsewhere and not a single thing
17,635
43,372
on some vans, it is easier and quicker to remove the sink bowl from the worktop to access the taps. also a good excuse to clean and reseal the joint to the worktop whilst the sink is out
