- Oct 5, 2012
- 4,300
- 9,573
- Carado T132
- 5 years, feel free to ask me about the Carado!!
Water pumps themselves don't really 'wear' and reduce in efficiency but if one developed a mechanical fault (e.g. a bearing badly worn or breaking up) the belt will loosen and probably jump a cambelt tooth or three which would most likely cause as much serious engine damage as if the belt had broken.
As already said, the labour involved in replacing the water pump later would be almost the same as for fitting just a new belt.
Late 2014 manufacture date as I remember.What year is your van as later ones pumps are more expensive and more difficult to fit
Just do it, too many people just want to skimp on the factory recommendations. They are recommendations for a reason.Hi all, I am getting my cambelt & ancillary belt replaced at 24K miles and the chassis by VIN number getting on for 6 years old. My thoughts originally were to get the water pump replaced as well, but should I ???? What do people think ???
On that model the waterpump comes built into a large casing you have to remove the pump to change it and that may require a new seal as well, the price can run upto £500 for the whole job if problems occur, £400 if all go's well. but do change it as a snapped belt caused by a failed pump will cost thousands.Late 2014 manufacture date as I remember.
I had the same with my LR, belt hardly worn at 7 years & 50K as I am a careful driver. My moho has never really been above 3000 revs, in my hands. The moho I expect could be the same, but nobody knows until the cover is off. I always had timing chains on my motorbikes.Just had mine done at 26k and 6 years. The garage looked at the pump and said it was o.k. The belt and pulleys looked almost brand new. It cost £400, it would have been an extra £250 to do the pump as well, I thought surely a pump is designed to do at least 100k? I didn’t bother. It annoyed me having to change the belt, whatever happened to timing chains?
