Shortening SMA aerial cables
Kingston upon Hull, East Yorkshire.
Hymer B544
2001 Caravans 2011 Motorhomes
I’ve just fitted my Panorama mimo 2x2 LTE/WiFi aerial but the cables it came with are 5 metres long so they are distributed along the back of the three adjacent cupboards and then looped back to where the router is going to be. Somewhat messy.
They need shortening to about 1.5 metres. I’ve looked on good old YouTube and it looks little different to a TV coax, of which I’ve done plenty, the only difference being the need for a particular crimper.
Anyone done it?
Any advice?
? Need for soldering.
The principle is the same as with TV aerial coax but at a tiny level. You need the appropriate tools, including specialist crimpers, a decent large magnifier and really nimble steady hands. Not one single thread from the outer braid can be left in contact with the inner core
Then you might get an issue with the shorter wire affecting the SWR of the antennae
If you spread the surplus wire along the length of the required finished length, then tape it into a loom, it would be much easier to conceal
I thought excess leads = signal loss
leads should be as short as possible
That can be true, as extra wire adds resistance, but if using to transmit and receive some antennae are very finely tuned, relying on the set length of wire
Maybe a radio expert like Jaws could help explain
I just coiled mine up inside the cupboard and it’s worked okay everywhere I’ve used it.
I shortened the cables on my old puck antenna using these and it worked ok but you do need the proper crimping tool.
It depends on the cable size you need to shorten. The adaptors Manic quotes are for RG58 cable which is around 6.15mm in diameter and if this is what you have it will be easy, it's just like TV antenna wire.
But if its like my Poynting antenna the cables are much thinner, I suspect its RG174 and is less than 3mm in diameter. I would be reluctant to do the job, RG58 will be trivial in comparison.
If you want to give it a go you will need something like this - but the actual connectors you need may be different but SMA male is the commonest.
Amazon product ASIN B08JLG3MWQ
www.amazon.co.uk/Coaxial-crimping-connectors-Antenna-Extension/dp/B08JLG3MWQ
reducing a cable at VHF by 1.5 mtrs is just not worth the effort as far as signal strength goes..
BUT.. I would not coil it up, you are effectively forming a choke at a specific frequency ( Mikeco )
Far better to sort of bunch it up randomly.. One of those times where neatness is not a good idea !
I’m fairly sure it’s RG58 but I’ll have to check next time I’m there, the problem with being in storage.
1.5 metres is about what it needs to be, rather than 5 metres, not shortening by 1.5 metres.
At the moment it is all coiled up in the limited space available.
Reactions: DBK
Thankyou and a good point but I probably was a bit incorrect to say coiled up as my cables were only 2 m long, I will however check tomorrow.
The frequencies are far higher than VHF on the higher bandwidths the loss is around 1db per meter and you only have 6db gain to start with.
Anyone who doesn't know what they are doing shorting the cables is best left alone as you need a good termination to avoid signal loss.
See John's post #9.
Reactions: DBK
Many years since I worked on anything broadcasting radio frequencies, so that part of mine brain is a little grey now
I did, that’s why I clarified they are RG58. I should have quoted him to avoid confusion.
The antenna is designed to be panel mounted and can be fitted on a conductive or non- conductive panel. Supplied with integrated flame retardant RG174 cables (Compliant to UNECE 118.01 and EN45545-2) and a halogen free flame retardant radome the antenna is suitable for many environments and applications.
from
from
I got it from CO-STAR and they say RG58 in their add, I’ll have to confirm tomorrow.
If you are sure it's RG58 (check diameter) then I think the jobs doable. The set I linked to above should do the job but if you want better quality connectors Messi & Paolini might be better. Not cheap though.
I’m not 100% sure until I go back and check, just going by the info on CO-STAR’s page.
Their description is wrong as on the same page it says the cable is C29SP-5SJ which is 5mm in diameter. This makes sense as the RG cables are not particularly good for high frequencies.
This supplier may be able to provide suitable connectors.
Just been to check before it gets dark and they are the 5mm ones you quote.
Co-Star said they’ll shorten them, probably cheaper than me sourcing a crimping tool that I may never use again
Even at microwave the loss over 1.5 mtrs it is very low..
Just pulled up the spec and it is 3dB over 10mtrs.. so loss over 1.5 mtrs about .5dB
Shortening the cable should net REALLY make any difference to the SWR as it it an unbalanced feeder and SWR should be dealt with at the antenna end and looking at the size and shape of the unit I would guess it is going to be shunt fed ( though that is a guess )
Reactions: DBK
Rg174 which is what my pointing aerial uses the loss is 0.75db per ft @ 2.4ghz.
Compared to C29SP-5SJ RG174 is a leaky hose :) It is air gapped double wrapped
Nope, he has the same Poynting aerial as me, he was talking about another one, but on our ones the cable is only 300mm long.
Ahhhh
