Self maintenance 2.3 ducato 130 2017
Northampton
Rapido & Bongone
Are there any sensible lists on what to do current 2yr 4400miles
engine service .
Oil filter and change .
New air filter
fuel filter when?.
Cluch brake fluid change (3yrs or measurement)
Gearbox oil change when?
Coolant top up .
Windscreen reservoir top up .
General check over and lubrication including turbo wastegate actuator , gearbox linkage. Any links picky vids etc
Alternator charging check
Anything else
Just bought multiecuscan so anything particular to check do?
have a look in the service book and it gives a guide also this may help;
Just had my Adria Serviced 7000 miles 2 Year plus
Local garage said oil and filter ( new fiat specification for Euro six 9.55535 ds1 ACEA 2 0W/30 )
Air filter , wiper blades,
asked about fuel filter he said three years and check brake fluid at same time.
Fiat professional would probably be different though.
Thanks gents
Totally forgot about book not got anything with my new upl all done online, will have to have a hunt. I was particularly interested in any known issues eg stiff linkages etc.
Oil and filter annually. Air filter every 15k. Pollen filter every 40k. Brake fluid check every two years. Timing belt every 5 years.
It's a commercial van designed for high mileage and few services
Anyone got a genuine oil filter part number please for 2.3 130BHP. I am aware my van is euro 6 and therefore needs new fiat specification oil for Euro six 9.55535 ds1 ACEA 2 0W/30.
Regarding gear box oil, if it's Comfortmatic seek professional help. Bleeding the system after changing fluid is very problematic. Needs to be done at 5 years.
As others have said the service schedule is in the Fiat handbook that came with the motorhome. The first one is after 2 years. Best to get that one done by a Fiat Pro dealer and the book stamped so no argument about warranty work.
If you have a UK conversion it will have a 3 year Fiat warranty, but if you have a European one it will be only 2 years.
Just found out you can use SHELL HELIX ULTRA ECT C2/C3 0W-30 on euro 6 , meets 9.55535 DS1.
Bit cheaper than some other oils but a make you can trust ( OPIE oils sell it for £48.95 on Ebay might be cheaper somewhere else )
on the pollen filter I have found that it needs changing every 2 years if you use it particularly in southern Europe for a few trips.
OEM NUMBER: 71779555 / 5801985959
If you are looking for oil that meets Fiat specification for Euro six 9.55535 ds1 ACEA 2 0W/30 then this also meets the specification - Millers Oils XF Longlife 0w30 C2 SN Fully Synthetic Engine Oil.
Bought 7 litres today at a very good price
I know ours is Euro 5, not 6 but it’s been serviced by Fiat Professional from new and they use FUCHS Titan oil.
When I ask for a top up bottle of the oil recommended in the service book (Selenia) they said they don’t keep it but could order me some, if that’s what I wanted.
