A friend of mine is installing a heki rooflight. What would be the best adhesive sealer to install it with please..
I used 512 to stick my solar panels on, was told not to use on roof lights incase you need to remove them.Sikaflex 512
I would still use it, no point in losing them on the motorway.I used 512 to stick my solar panels on, was told not to use on roof lights incase you need to remove them.
Bad advice.Sikaflex 512
Don’t agree, how many people have ever had to remove a roof light.Bad advice.
Use non setting like the makers do.
You can't lose a rooflight. The frame clamps the roof between inner and outer. You can of course lose the opening part but the best adhesive in the world won't affect that.I would still use it, no point in losing them on the motorway.
Me on every leisure vehicle I've owned because of poor OEM installation, or brittle plastic breaking, or because I wanted one with a fan, or to replace a translucent version with a transparent one, or to replace one with a failed winder, or because I wanted a bigger one.Don’t agree, how many people have ever had to remove a roof light.
Not quite true in some cases, the midi-Heki I fitted has small clamps that rely on clinging to the underside edge. The inner section with the blind is held in place by by spring toggles, no scewed connection to the top frame at all.You can't lose a rooflight. The frame clamps the roof between inner and outer. You can of course lose the opening part but the best adhesive in the world won't affect that.
I would use Sika 512.Thank you everybody for you input. I seems none setting mastic would be the best. Ive got a tube of the Hodgsons seamseal,do you think this would be ok. Its a none setting mastic..
The small clamps are exactly that. Correctly installed it wouldn't matter whether sealant or adhesive was used or not - the rooflight would stay in place. It would however leak .Not quite true in some cases, the midi-Heki I fitted has small clamps that rely on clinging to the underside edge. The inner section with the blind is held in place by by spring toggles, no scewed connection to the top frame at all.
I a roof light for a friend, she said she had bought all the stuff so I stuck it on with the Sika adhesive she supplied, a year later it was leaking again so I would be using non setting mastic
Martin
It was a few years ago and I know more now than I did then or I think I do.Surprised you fitted it, I would have told her to buy the correct stuff first or I'm not doing the job.
