Screwing in a Motorhome
Vanman
Runcorn
Roadscout R PVC
March 2017
Ooo errr Matron!
(Sorry) (y)
When we get our new PVC there will undoubtedly be things that we'll want to screw to the walls - I'm thinking Fire alarm/blanket/extinguisher, holders for stuff, brackets etc. and I was wondering, as we'll almost certainly pick all the wrong places first time, whether there's any fancy substitute for the good old fashioned screws that can be removed without leaving scars? Blu tack and 3M sticky hooks are unlikely to be heavy enough duty I suspect, I want to be able to hold things weighing 3 or 4 pounds despite going over the local speed humps at normal speed ;)
If the van's a' rocking, don't come knocking...
Not really any substitute for screwing into the wall, especially when it comes to securely holding on the heavier items...
Not so much as we get older, we do like a nice meal though:)
Screwing in the van has been banned at present by the wife unless in the garage. Extra strong velcro holding up cargo nets has been allowed and appears to keeping it up and there is some weight attached
Sorry.....do you mean your wife has to be in the garage?? And what are the Velcro nets holding up?? I'm fascinated by this thread.....
It depends what you're screwing to. If you need to spread the load you can Sikaflex backing plates (wood or stainless) to the wall.
Depends how they build the van, on my own coversion I have 9mm of plywood on the walls so no problem.
You've gotta be careful of hidden cable runs (like lighting cables run behind. cabinets).
I use a hot glue gun for some stuff (like an extra mains extension socket block or hooks). Sticks like s**t to a blanket! And, you can get it off again with dental floss.
Doubt if that would hold an extinguisher, but it does lighter items a treat.
Watch those darn cables if drilling, or worse, gas and water pipes at a low level!
I always use a wire/stud detector if not sure of what's behind.
A small pilot hole will give you a clue how thick panelling is so if using screws you can keep the length at the optimum to just pierce through.
The inside of the PVC should be lined with plywood or similar. Best to ask the converter re thicknesses and lining material used.
When depth is critical, I've drilled a pilot hole (diameter of the core screw thread) and used a grinding wheel to reduce the length of the screw to the desired length.
Stick and stick Velcro is surprisingly strong and you can change your mind later. We use it for fire blanket, mobiles, remotes, sockets, meters etc.
Reactions: Pia
The wife has to be present for screwing purposes. Because we have a new van, and i m a man, and i have the tools, I need to screw. She wont let me screw in the habitation part yet. i m sure there will come a time. So as a compromise I have put up extra strong velcro which the cargo nets stick onto. They hold all the maps inside behind both front seats and other things that may be needed whilst driving.
In the garage (or should i call it the dungeon in this thread?) I have been allowed to screw under her supervision. I have screwed bigger stronger cargo nets straight into wooden areas and these hold the cadac, beach mats and collapsible chairs.
Hope that confuses any ambiguity previously caused
I have thought about this many times in the Moho but my wife won't let me screw in it. Sensible really as don't want to create damp patches in holes made by me screwing. Velcro and them sticky hooks is the answer for now.
Good question raised here. I keep meaning to ask what is the situation about screwing into the ceiling, as I am thinking of putting up some sort of curtain rail across the cab (Ducato) on the hab side
Or is it a question of Sikkaflex?
Could try a wall to wall telescopic rail.
These are good for covering screw heads and mistakes. Lunar used them all around our van.
We screw in ours, (y)(y) when it gets to a certain age you have to screw where you can, not damaged anything yet:D
spot on with a suitably sized screwhook in the centre, did this in a pvc 2 vans ago across the cab area and across the back doors looked very cosy and it was(y)
Ahhhhhhh, but did you have to screw the screw hook, which you used to support the pole which stopped you having to screw in the first place. :)
Steady Sooperdooperwinabagelmike , the thought of too much screwing at your tender age could be risky :D
3M hooks which can be removed without a trace for flannels and the like, stick & stick velcro for CO alarm and similar & finally for heavy items like fire extinguisher, wine bottle holder I use T-nuts ....
Link Removed​
Need to fit some corner steadies and make sure they are down before you start screwing if you don't want your neighbours to know what you are up to.
If you get a thick enough pole you don't need to screw it in the centre as it won't flex ... I speak from experience! :D
