Anyone used Smart Switch if yes how was it...
Oh that's not so good is it....General question, any other ideas for transferring from Samsung to Samsung......Not good, it gets to the final section, and then says error when trying to sync Outlook on my S7 and Tab 2 tablet. This is syncing through a win 10 computer.
It used to work up untill 2 updates ago.
Thanks for that I will down load it and try on a couple of older phones first just for practice.I've used it on a s5 to s7 and then from the s7 to a s9+ without any problems whatsoever
Did you already have anything on your Samsung S8, if you did was it wiped or changed during the transfer in any way. Just asking as my recipient Samsung does already have quite a bit on it...ThanksI used it from HTC one to Samsung s8. Worked perfectly,![]()
Thanks scousbird that is reassuring....I've used it a few times and even from Alan's very broken phone (it was run over at work) to the lappy then to his new phone. Worked well every time.
No, the S8 was new and empty.Did you already have anything on your Samsung S8, if you did was it wiped or changed during the transfer in any way. Just asking as my recipient Samsung does already have quite a bit on it...Thanks![]()
Just back up the S8 first. If anything gets changed just restore from the backup. If it doesn't then fine. Simples.Did you already have anything on your Samsung S8, if you did was it wiped or changed during the transfer in any way. Just asking as my recipient Samsung does already have quite a bit on it...Thanks![]()
