PJGWiltshire
Some comfort advice from any in the know.
We are due to set off for a few months run around. As per normal during the preparation stage there is always something found to be bust.
In this case its the old Sat Nav system,
It appears that the battery has failed and a replacement cannot be obtained prior to our departure date at the end of next week.
All is not lost: The Sat Nav works when plugged into 240v but the battery will not charge or hold a charge.
My question to help me sleep easier is around running an inverter full time whilst driving along.
You see I can switch the inverter on and then the Sat Nav will be fed on 240v supply and then the little box can guide me to pastures new.
From anyone out there in the know, will the running of the inverter, (obviously only drawing the power to operate itself and supply a few amp draw to run the Sat Nav), whilst driving along cause any issues. The batteries would not be drawing very much but at the same time would be receiving a charge from the B2B. Does charging and drawing at the same time cause issues with the batteries.
Any guidance would be helpful
