Rubber bumper seals
Hymerbell
Winchester
Hymer 674
Since 2002 plus 20 years in a tent
Anyone know where I can get rubber bumper and wheel arch seals for a Hymer 2004. Ivectried all sorts of restorative potions but still looking old
I can’t help but I’m in the same position as you mine are the same as yours hard not so supple
Have you tried Plasti-dip spray paint?
Tried everything...including an expensive bottle of something which come in a minute bottle...can’t remember it’s name...new ones are the only answer...
I don't think it is rubber, more a flexible plastic, so the only answer is replace or paint with the correct type of paint
I've seen them on Ebay bought by the meter ...
Mine are hardened too but as they dont actually serve much purpose other than cover the screws I'm not fussed.
Try these people, <Broken link removed> Also have you tried contacting the manufacturer, It's very likely that they will have a stock of spares, and if not then the name of the manufacturer who made it for them.
Best of Luck!!
Russ
Brownhills maybe ?
They seem to have quite a stock of older Hymer parts.
I usually give mine a coat of Back to Black each year, or diesel smeared on a rag and rubbed over works for a time.
WD40 on a clean rag usually brings them up nicely. Might need couple of applications.
Brown hills do sell the seals but they arent cheap ...I priced up to change all mine last year and it was about £200 to do them all
I find a hairdryer held on them brings them up then a bit of trim black
