Reversing camera options (1 Viewer)
Bart
3,188
1,398
Northern Ireland
Boxer L4H2 van build
Since 2016
Hi I would like to upgrade or change my reversing camera / screen that came with our Autosleeper kingham , possibly without spending a fortune. :)
The system comprises of a small reversing camera mounted up above the rear doors , then in the cab the image is displayed on the Garmin Camper 660LMT-D once reverse gear is selected.
The image is crap to say the least , especially at night , so I'm not sure if I'd be best replacing the camera for a better one , or replacing the screen ( which also is our Sat Nav. )
Camera ..
Sat Nav
Sat Nav connection ( not sure is the camera connected via Bluetooth ) ??
Aug 25, 2016
1,098
5,753
Taynuilt, UK
Hymer 655 Starline
Village idiot
Looks like a standard satnav power connection so I would presume the camera is wireless I have a more recent garmin satnav and the camera šŸ“· is wirless like yours.
Bart
Bart
3,188
1,398
Northern Ireland
Since 2016
Is your camera image good , especially when a bit dark , are you happy with it ? If so what camera do you have
Jul 29, 2013
9,074
18,615
Salisbury
Hymer B678DL A class
You will probably improve the image with a hard wired camera and screen.
I bought one for a side view as we are lhd and it works fine about Ā£30 on flebayšŸ˜Š
Bart
Bart
3,188
1,398
Northern Ireland
Since 2016
That is what I am wondering , if the quality suffers because it's not hard wired , do others here get a great picture when using Bluetooth ?
Marmite
161
672
SW Hertfordshire
Dethleffs T 6757
Have twin rear view cameras .. parking camera to 2-DIN unit and nomal rear virew camera to clip on screen over rear view mirror. ... both hard wired. Works a treat.
BTW .. I thought that a rear view mirror was a legal requirement, irrespective of whether you can see anything at the rear?
StephDeLux
481
797
ML-T 560 built
I have a Garmin BC40 camera on the front, it connects wireless with the Garmin Camper 780 and the image is very good, including at night albeit then in black and white.
It also looks like I could add more BC40 cameras, which is pretty tempting for side views and even a view on the grey water pipe.
When I say wireless, I'm not sure if it is bluetooth or an ad-hoc wifi network.
cmcardle75
2,666
3,446
Reading
Riot Van Conversion
I understood you legally needed 2 rear view mirrors. One must be on the right (wing or door), the other on either the left or on your windscreen. I've driven many vans that have clearly never had a window mounted mirror (for obvious reasons).
Camdoon
1,531
2,808
Adria Matrix Supreme
No windscreen?
Apr 22, 2018
6,827
12,596
Herts.
Adria Coral lowline
Rear bulkhead In way, or no glass in rear doors, I would think. Fairly normal for commercial vehicles.
Bart
Bart
3,188
1,398
Northern Ireland
Since 2016
Yip I've driven quite a few "white vans" where there has been no rear view mirror as you just have the full bulkhead behind the front seats.
68c
Oct 22, 2019
1,822
2,804
Southampton
2001 Pilote 270
I fitted a dual camera reverse/rear view mirror setup. In truth I rarely look at the reverse picture when backing up, either use the wing mirrors or one of us gets out to guide if a tight spot. The rear view mirror function is handy, often see a car close to me that wing mirrors do not show. As mine is an old van I get sorely tempted to brake hard when I see an expensive car tucked in there. It was not the cheapest kit but I have found the display not bright enough in the sun, tried mounting mirror in the conventional mirror position but unusable on a bright day especially when against white clouds. Now mounted to the right on the dashboard but still too dim. Playing around with brightness, contrast etc has not helped much. When riding as passenger I sometimes use the remote control to select reverse camera to check the bikes are secure.
Bart
Bart
3,188
1,398
Northern Ireland
Since 2016
I have a question that will help me decide what path to take.
Is there anyone here who uses the Garmin 660 who has a good image from their reversing camera , and are happy with it?? If so what camera do you use ??
, as from reading up on the camera that I have ( the Garmin BC 30 ) the resolution of it is only 680 x 480 , however if I did just change the camera I would still be limited by the screen resolution of the Garmin 660 which is 800 x 480.
I have looked at upgrading the camera to the Garmin BC 40 who's resolution is up to 720p ( Sat nav dependant ) , but unsure what it's resolution would work out at when connected to my Garmin 660.
StephDeLux
481
797
ML-T 560 built
According to Garmin, the BC40 is not compatible with the 660.
Bart
Bart
3,188
1,398
Northern Ireland
Since 2016
Thanks for the heads up , where did you read that info please
AndyPK
5,020
13,972
Cirencester
Noneā€¦ā€¦..!
Motorhoming since 2015......
The Garmin website has a list of compatible sat navs......
AndyPK
5,020
13,972
Cirencester
Noneā€¦ā€¦..!
I have a BC40 and Garmin Drivesmart 55 for reversing, and a wired camera linked to the rear-view mirror monitor for driving.
Bart
Bart
3,188
1,398
Northern Ireland
Since 2016
Hi Andy , yip I just seen that at the Garmin website there , my guess is that the camera will connect to the Sat nav as it's just a Bluetooth connection , but whether it will display a picture due to the camera resolution of the BC 40 being higher that the resolution of the 660 Camper Sat nav.
