That's incorrect.As far as I know you need a rapid antigen test which needs to be taken 72 hours before your travel - you have to upload a photo of your passport and the result to the manufacturer to verify it. They'll then email you a certificate to confirm the test reading.
If you go to the Eurotunnel website it will tell you what you need to upload to them.
Did you not look into this before travelling?Hi, driving back to uk using tunnel next week what test and paperwork do we need to present to whoever.
Thank you.
I never got asked for mine when I went into France but just to be safe before leaving home I did print off a few copies of the forms needed from Amber & Green countries.That’s my understanding too. But are you going to complete another “sworn statement” when you go from Spain to France?
Yes as I said within 48 hours of your return, you can't submit the form before 48 hours until you travel.Did you not look into this before travelling?
Has it changed recently?That's incorrect.
You need to order the test to be delivered to your home and you have to take the test by the second day you arrive home.
You have to fill out online the Passenger locator form upto 48 hours before you travel and put the reference number of the test you ordered on it.
Yes,you only need plf and to have booked, with qr code, the day 2 lft test now.Has it changed recently?
We ordered two packs prior to our trip, one to do whilst away (no earlier than 72 hrs prior to travel) and a test to carry out at home after 2 days.
We've done the rapid antigen tests and have the results which we need to travel. We also have the reference numbers for the tests to be carried out at home which we need to enter onto the PLF form.
No.Can we use the ones we got from the NHS before left the uk we have 7.
That explains it... thanks.Yes,you only need plf and to have booked, with qr code, the day 2 lft test now.
Thread 'Driving to Spain and back'Didn’t know I had asked this question before
It was all different then, you had to have a test 2 days before entering UK and maybe an 8 day one? Anyway that's in the past for now.Did you not get the answer to this question when you posted on Sept 8th when going to Spain?
https://www.motorhomefun.co.uk/forum/threads/driving-to-spain-and-back.248604/
Absolutely, why should the OP be given the third degree with evidence of a previous post it’s not a court of law. Just pass by.these things have been changing nearly every week. cant a member ask for confirmation? its better to be sure , even if it upsets some forum member.
I will be on the move shortly, what if you fail the test ? Would you you have to isolate risking a possible overstay? and wouldn’t it be wise to order extra kits as l presume you would have to go through the process again to get the all clear. It all sounds a bit impractical.I'm a bit concerned that the original poster hadn't bought the 2 days test prior to travelling. Will this affect his travel? Eurotunnel seems quite clear that the test should have been bought prior to travel. I wonder what happens if the procedure isn't followed?
You book the Lateral Flow Test BEFORE you enter the UK (or preferably before you leave) so that you can enter the serial number(s) on each passenger form.I will be on the move shortly, what if you fail the test ? Would you you have to isolate risking a possible overstay? and wouldn’t it be wise to order extra kits as l presume you would have to go through the process again to get the all clear. It all sounds a bit impractical.
No you have to book a lateral flow test for either at home or at a clinic ----- beware because it is a minefield.Can we use the ones we got from the NHS before left the uk we have 7.
Correct. Just one wrinkle that I've found.No you have to book a lateral flow test for either at home or at a clinic ----- beware because it is a minefield.
We eventually used Dam Health - they seemed efficient and professional we paid £28 to attend our local clinic within two days.
Home - DAM Health
Welcome to DAM HealthDAM Health is one of the leading providers in the UK for COVID-19 testing solutions. Book Your TestExpress TestingWe are pleased to now offer guaranteed results within 3 hours in some of our clinics!Where are you flying?We have test centres across the globe. DAM Health in...www.dam-health.com
You also need to fill out the online location form including the reference number your testing company will give you.
You need to download all this to Eurotunnel - if not you will need to park up and enter the terminal building for manual checking and to collect a boarding pass.
How can it be bought before travel if,like me, you are entering UK for the first time. Sounds like it is badly written and means before travelling IN to the UK?m a bit concerned that the original poster hadn't bought the 2 days test prior to travelling. Will this affect his travel? Eurotunnel seems quite clear that the test should have been bought prior to travel. I
You buy online via their website.How can it be bought before travel if,like me, you are entering UK for the first time. Sounds like it is badly written and means before travelling IN to the UK?
You can buy the lateral flow test as you arrive at the tunnel if you wish, they email you the code you need for the plf in minutes with another email to book your test. As ours are at the house we’re having a video call with a Nurse on our second day back then we just pop them in the post, be aware if you make a clinic appointment they’re every 15 minutes and you can’t be late or you get charged. Fingers crossed you haven’t used all your data roaming but that’s another story!How can it be bought before travel if,like me, you are entering UK for the first time. Sounds like it is badly written and means before travelling IN to the UK?
