- Feb 24, 2013
- 12,997
- 101,185
- Hymer S800
- not long enough
A couple of years ago I noticed water inside one of my side plastic windows
turned out we had a crack / split along the top, took window off and tipped all water out
next rain it half filled again, as taking off was slightly risky as in i could break it completely, so I then drilled 2 x tiny holes in the bottom and it drained slowly.
I did try some plastic sealant on the window but without success, but the split ran virtually right across the window
thought my drainage solution would make a permanent fix, but the window steams up a lot and then developed black mouldy spots inside
today at long last I got round to sourcing a new window, I had expected a much bigger cost, but sent this photo to Leisure Spares
within 10 minutes they called back , not in stock but can get, it comes complete with all catches and hinge , delivered £240 which I didn’t think was too bad and about half what I had guessed
now hoping it arrives in time to take to a rally with competent and willing attendees to help swap it
Search Results - Leisure Spares
Search Results - Here at Leisure Spares we specialise in providing genuine spare parts directly from manufacturers for the caravans, motorhomes and other leisure industries.
www.leisurespares.co.uk
