Dave1966
Hi funsters,
I need to ask the advice of you all as I have to replace the cab (starter) battery on a 2021 Fiat based moho.
Based on previous stories of airbag ECU failure etc etc, are there any precautions I need to take - other than the usual when changing a battery on any vehicle. I'm aware that the alarm will activate (probably) and I need to put the tracker in a maintenance mode, it's just fears of ECU damage that I'm looking to guard against. The van also has a Vanbitz battery master so there will probably be a small amount of charging current when I disconnect the battery.
Thanks all.
Thanks all.
