Renogy dc dc mppt with schaudt 99
mirkus
Motorhome
Hello guys :)
I need help to connect the dc-dc mppt charger, cause I don't know how bypass the ebl 99 :(
Can someone explain me, what do I need do?
It depends on the output of the Renogy unit. If it is within the capacity of the EBL it is fairly simple and you can intercept the existing engine battery connection to the EBL. If it exceeds the limit of the EBL then you need to wire it directly to both the engine and leisure batteries and then disable the original engine battery (alternator) to leisure battery charging circuit. If you wire it directly and leave the original circuit in place you will create a loop from the leisure battery side of the B2B back to the engine battery, which can mess lots of things up.
Yeah.. The problem is, that the renogy is 60a and it exceeds the limit of the ebl.. What if I remove the d+from the ebl? I believe that this could be works
My previous motorhome had an EBL. Initially I wired the B2B up without disabling the original circuit and strange things happened. Fortunately it was a Votronic unit and I could limit the output to EBL compatible levels so I was able to wire it up via the EBL and the strange things disappeared.
One possibility is to remove the main 50A fuse on the Starter Battery wire. That's the one that goes to the connection at the back of the EBL (The heavy-duty screw terminals). That wire is only used for the split charge relay, not for anything else. Then wire the B2B directly between the batteries, with suitable wire and fuses, bypassing the EBL.
For anyone else looking at this, if the B2B is 50A or less, it can be put into that starter battery wire by any convenient method. For example, remove the starter battery wire from the back of the EBL, connect it to the input (Starter battery) side of the B2B. Run a new wire of the same thickness from the output (Leisure Battery) side of the B2B to the Starter Battery input at the back of the EBL. It won't be suitable for the Renogy because it's 60A.
The fridge on 12V, and the starter battery charging on EHU, will still function because there is a second starter battery wire (with a 20A fuse) that provides this connection.
The D+ is needed to switch the fridge relay. It will switch the split charge relay too, but if the 50A fuse is removed, nothing will happen.
Pin 2 of the 4-way connector on the EBL is a D+ signal, and you could connect into that wire to get a D+ control signal for the Renogy B2B.
Hi, I am wanting to connect my Renogy MPPT to the EBL 99. Mine is the 20amp version so I want do as you suggest and connect to the EBL directly.
The motorhome currently has a single lead acid battery connected. The Renogy MPPT has multiple charge types so do I simply select the Lead Acid charge type or do I need to do something else as I am connecting via the EBL?
MPPT-
Rover Li 20 Amp MPPT Solar Charge Controller​
Select the charge type on the Renogy MPPT. The charge type selection switches on the EBL front panel only affect the EBL internal mains charger output, they have no effect on anything else.
