Just joined and before we head off anywhere we need to get rid of the smell of dog from the upholstery. I am thinking that steam cleaner hire might be the only option. Has anyone experienced this and solved the problem? Thank you
Hi Janine, yes I have and to no avail. Thank you for replying.I think that wetting the upholstery would make it smell like wet dog rather than getting rid of the odour.
Have you tried spraying it with Fabreze?
Thanks, will give it a go ?You could try this but you have to get it wet then let it dry out View attachment 344908
From most pet shops .And it works
Cheery Jev, thanks for all your help today. Great to see you & Karen ??Combination of things worked in our MH.
Removed all covers we could and washed.
Took all carpets and cushions we could outsdie and steamed them and gave a generous, vigourous rub.
Then steamed all the upholstery that isn't easily removable along with the roof liner inside.
Used the foaming stuff sprayed on the front seats and rear carpets.
Then cheapo version of fabreeze and a good mild detergent/disenfectant on all hard surfaces. It was a lot of elbow grease but appears to have worked.
Will check ?Have never looked but can you unzip the upholstery and put it in the washing machine if it's fabric
Thank you ?Hire a hot water extraction machine that has an upholstery tool and follow the instructions but before you do buy some of this and use it as directed.
Kill Odour Plus (5L) - RESTORMATE CLEANING SUPPLIES
www.restormate.co.uk
Then make Sure you dry at as quick as possible using fan heaters or whatever or the bacteria will start to smell again.
Foam type upholstery cleaner rather than soaking the fabric.
As nearly all used motorhomes are advertised as having no pets, and we know a large number, if not the majority of motorhomers have dogs, someone may be being economical with the truth.This is the reason I would never ever buy a second hand MH that has had dogs in it, I personally don't think you can ever totally get rid of the smell but I wish you luck
I didn't even look at your avatar to see it was you! ?Cheery Jev, thanks for all your help today. Great to see you & Karen ??
P.s. I have an old steamer you can try - let me know and can drop off. It's a steam generator rather than a proper carpet or upholstery washer like you can hire at supermarket. You will need your own cloth to wrap around the steam head, available in cheap jumbo bags on eBay.I didn't even look at your avatar to see it was you! ?
