We have a problem with central locking of the habitation door. Problem was that two of the cables had snapped at the base of the doors, probably due to continual flexing. the green wire coming to the door (from the bodywork) is very short and i effected a temporary repair whilst in Spain in the Spring. i used a connector block that i could push onto the wire and tightened it as much as i could. it worked for all the summer.
However to keep it dry and to offer some strengthening, I wrapped the visible wires with self-amalgamating tape that I've used successfully for many years when i messed about with a moveable satellite dish. I now need to remove the tape to see if i can make a more permanent connection of the broken wires. Trouble is, i was over zealous with the tape and it does what's it's intended to do. it sticks like the proverbial to a blanket.
Apart from sitting on the van step with a scalpel, is there anyway of removing the horrible stuff without damaging the very thin wires underneath it? How I wish I'd just put on only one layer!
