- Apr 11, 2017
- 1,482
- 7,201
- In between
- started Oct. 2016
There's always oneNot what i was expecting when i saw the title
Or twoNor me!
I think the problem here will be no permanent power as the high level light is only a brake light.My one is wired by the factory but if I was installing it myself I would be looking at a wireless one
https://rover.ebay.com/rover/1/710-...0001&campid=5338547443&icep_item=402300257373
Is it powered or does it use batteries?I have a wireless one from Falcon which I occasionally use. I run my sat nav on a tablet so I run the camera App on the same tablet and switch to camera view when needed.
ezee
This may be the solution. How long do the batteries last before you need to recharge them?Its uses rechargable batteries. See the Falcon web site. Go Outdoors also sell them.
ezee
To be honest, not sure as it has never run out on me on the trips I have used it. It has certainly been ok for 3 hours or so and then I have always put it back on charge.This may be the solution. How long do the batteries last before you need to recharge them?
Thanks for taking the time EzeeRider I was hoping to mount the camera high up by the brake light so not easily accessible. But still worth considering due to the advantage of no wiring.To be honest, not sure as it has never run out on me on the trips I have used it. It has certainly been ok for 3 hours or so and then I have always put it back on charge.
ezee
Thanks ManTheVan but I was hoping not to wiring up the van. But, £280 all in sounds ok.I just installed a twin lens HD replacement for the original Waeco camera which was no longer viable. This came from reversingcamerasuk.com which is a UK supplier specialising in just reversing camera systems. The unit gives stunning clarity both during daylight hours and in total darkness. It gives a permanent narrow-angle far distance rear-view while the engine is running and switches to a wide-angle near distance when reverse gear is selected. The twin-camera unit and a 7” rear-view-mirror mounted HD monitor with all the cabling came to £200.
There is a 4-pin cable that needs to be run from the rear to the front, then wired in to the electrics. The job was completed by a local mobile caravan servicing specialist who charged £80 all in.
Worth every penny.
You still have to provide power to the camera. One wire instead of two still a threading problemMy one is wired by the factory but if I was installing it myself I would be looking at a wireless one
Sorry didn't see this before my previous post. Ivpe never come across a battery one, must investigate as its one of my jobs when I can get bkack to BostonIts uses rechargable batteries. See the Falcon web site. Go Outdoors also sell them.
ezee
try falcon, not far away ok. ok pjI have a wireless one from Falcon which I occasionally use. I run my sat nav on a tablet so I run the camera App on the same tablet and switch to camera view when needed.
ezee
just ask falcon, no liky no buy-y i like the one they did for me,please dont creep up on me from be hind, i can see u. ok pjIs it powered or does it use batteries?
It took the guys just over 2 hours to strip out the old system, run the new cable (it’s all inside, not ducted beneath the van), wire it all up, aim the cameras and tidy up. I think the wired solution will be much more reliable for you, but have fun doing the research, as I did!Thanks ManTheVan but I was hoping not to wiring up the van. But, £280 all in sounds ok.
Depends if you use it as rear view mirror will then need ignition feed. However i did see a later post about battery driven ones tbat I hadnt heard of which would solve that problem possibly. It depends whether you can switch them off when not in useOnly down to the reversing light bulb maybe - not the full length of the van
