Rear of Motorhome sitting low over wheels - Elddis Autostratus 1998 (1 Viewer)
Jun 4, 2016
31
54
Colchester
Elddis Autoquest SE
Very little - 6 months
Hi there
Has anyone had an issue with their motorhome sitting incredibly low over their back wheels? I am a little worried we may have a rear axle issue (which sounds expensive?)
The gap between the tyres and the wheel arch is only about a fingers width on each side of the Motorhome. Its been like that since we bought it and it passed its MOT, but we had a Motorhome expert out today and he he did say it looked very close. However, he wasn't entirely sure what it could be, or whether the Elddis Autostratus makes do generally sit very low.
We do have quite a heavy bar at the back which looks like it used to tow a car, which I thought would be weighing it down, but the MH expert said, it shouldn't really.
He suggested I search it on the internet to see if its a common issue, but I cannot find anything and so, I thought I would post on here to see if anyone else has had these issues, or something similar. Its on a Peugeot Boxer chassis, so not sure who to refer to for an opinion?
Any help would be very much appreciated (I attach photos, too). I've also got more photos of the underside, too if that helps?
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
Many motorhomes have been built with rear wheel arches close to, or even partially covering the wheels, some are almost impossible to remove the wheels from. Ignore the wheelarch to wheel for a moment and look at how the motorhome sits when parked on level ground. The usual stance is slightly nose down but some can sit level. What you don't want is for the motorhomes are to be dragging on the ground. How do the rear springs look? The should be lower in the centre than at their ends. It is possible that the springs have sagged with age so it may benefit from new springs or auxiliary air suspension.
D.
3,876
5,283
The City of Henlow
Adria Supreme
Since 1980
I had similar problems resulting in damage to the rear plastic fittings where they hit the road. My answer was to have air-suspension fitted.
Looking at your van as it is, I would be interested to know if the payload allows for what is already pulling the rear end down. Could have been overloaded in the past leaving the springs a bit tired.
13,093
101,523
Bolsover, Derbyshire
Hymer S800
not long enough
slightly tongue in cheek, but is that plastic wrap heavy?
I recall reading that metallic paint adds weight
But as the whole thing is wrapped I really cant see affecting the rear only
As said above is it level on the road? could all be an illusion due to the wheel arches :)(y)
8,493
11,530
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
They all look a bit low. Get your head underneath and make sure there is a gap between the body and the bump stops on the springs.
53,549
150,497
I would go to a weighbridge and check your rear axle loafing is within limits.
Towbar can add 50kg plus and being right at the back wiil add more to the rear axle.
ambulancekidd
Sep 23, 2014
10,375
28,401
Ayrshire Scotland
Swift Kon-Tiki 640
Not the same type of motorhome but running on a year 2000 Peugeot Boxer. Ours is loaded for holidays in this picture & as already said, they do normally run nose down. Hope this helps.
D
deleted-member02
Did I read on the other thread that you're travelling with four kids?
I'd be inclined to visit the weigh-bridge fully loaded to confirm that your running within the vehicle's limits.
As already mentioned, air suspension would help and not too expensive....
17,637
43,421
The rear leaf springs are prone to sagging and in some cases can be refurbished or better still replaced with an uprated version. these are or were available off the shelf reasonably cheaply
chrisgreen
Jul 26, 2009
5,980
12,332
england
c class
since 2004
the OP'S motorhome has no rear springs,its an alko chassis with torsion bar suspension.
same motorhome as mine,and looks normal to me(y)
17,637
43,421
sorry, bad memory, i thought i remembered that van was on the fiat chassis. As you know with the alko torsion bar suspension regular greasing with the wheels fully of the ground is essential. there is a firm that refurbishes alko axles up in scotland, but the name currently escapes me. They either do exchange axles or you send yours and they refurbish fully and return in about a week
edit
it was annoying me not remembering, so did a search
http://www.fraserbrowneng.co.uk/index.php?c=al-ko-axle-repair
17,637
43,421
Does this type of suspension degrade with age like a leaf spring can?
yes because the torsion bars are constantly under compression. they tend to sag over time, but worse still if not regularly greased right, the torsion bars snap inside the axle tube one at a time (there are 4 either side)
Chris
21,056
279,143
10 years
Mine was low last year, but that was due to me having 3 slabs of San Miguel in the boot.
teknik155
204
180
irthlingborough
c class
since 2002
hi there Faye love the van colour. I've got the same van as you an elddis autostratus EB on an 1999 or 'V' plate and you're about right on the suspension. When you get the van serviced lift up the rear of the van until tyres are just resting on the ground and find the grease nipples on either end of the torsion tube squirt as much grease as you can. The Alko manual that that came with my van says that they recommend Shell Retinax LX grease also if you are using 205/70R15C tyres then they recommend 60psi and 65 psi.
With reference to your damp problem I would say that the damp is coming in via one or both of the 2 roof seals. It's a dumb design where the roof seals are in the dip of the roof. My fitter removes both of these seals every 3 years and reseals them and using some old blocks of wood I give the van a lean to the side preventing the rainwater sitting on the seals.
I am personally thinking of getting the roof covered in a flexible membrane to seal up these joints. But as we like the hot weather it will probably be in white.
If you want some copies of the paperwork that came with the van then ask as I did a set of copies for "RS_rob ".
I have the following manuals:- Carver ,Alko Peugeot and Elddis incl wiring diagram. Unable to do it immediately as I've still got a month left of touring round Hungary to do.
But as always any problems just ask
teknik155
204
180
irthlingborough
c class
since 2002
Just found a photo of mine to compare to yours.
At the moment I have 4 horizontal fingers of Tyre between metal wheel and wheelarch
1998 Peugeot Boxer
Hi there
I have the 1998 Peugeot Boxer Autostratus 6 berth and it sits in exactly the same orientation as in your pictures. So perhaps they are meant to be like this.
Badknee
7,408
413,592
notloB
Vantage Neo
Living the dream.
A very old thread resurrected, well done đź‘Ť
Two suggestions I would be thinking about if it was mine, spring assisters or air bags to lift it an inch or two. Contact SAP in Doncaster and have a chat.
Good luck with it.
3,743
7,452
Eye, Peterborough, UK
RV
FourWinds Windsport 6.8L V10
Some will talk about air suspension and air assist but in your age of van with alko torsion bar tube suspension there aren't any options to do this (at least not when I looked). If you have already lost a tirtion bar inside the tube or it has not been greased at least every year then new rear suspension tube required. Roughly ÂŁ3000 fitted and are made to order.
