Rear lounge or fixed bed
Van
15 yrs
I’m sure this has probably been asked countless number of times but I can’t find anything on the forum. We are looking at a two berth around 6. 5 m length home. Mostly for use in the UK but possibly two weeks in Europe. We don’t want an overcab one.
Just wondered what people’s views were on rear lounge v fixed French bed?
We have had a Vw camper for 15 years so are used to lack of space and making the bed up!
We've had vans with both rear lounge and fixed bed.
I prefer the fixed bed (and often sit there to read or knit / crochet) with back against the bulkhead and loads of pillows) as making up a bed is a pain - literally. When we had the rear lounge we would often leave the bed made up. I also like the garage under the bed.
We only take the supplied dinette table (big and heavy) with us if we need it to make up the lower centre bed and have a folding table instead. That way there is loads of room in the dinette.
Another solution for you might be a drop down bed? There are a few layouts with a drop down bed over a mid-ships lounge.
:welco:
We wouldn't even consider a van without a fixed bed, who wants the hassle of making a bed up every night then sleeping a miss match of lumpy cushions.
Our first van had a French bed, not a bad layout but limits storage space, our last two vans have had single beds at the rear that gives a nice big garage and a front drop down double bed. A Class vans give the best compromise when it comes to beds and storage.
Fixed French beds usually have a corner that is cut off, so as not to impede access to the washroom. If you can sleep well despite that missing bit of mattress, fine, but I don't think it suits everyone hence the French Bed layout is less common than a few years ago. One of you will have to climb over the other to get to the washroom in the night.
There are MHs and even PVCs with a rear lounge and drop down double bed so that ticks both boxes.
Fixed French bed.
I don't like the rear lounge types, the seating always seems too upright to lounge.
The two best seats are the drivings seats - turned around they become the perfect lounge ----- with a coffee table!
We've had two Burstner T660 over the last seven years. Perfect for two and you don't have to go to bed at the same time
I'm just converting a Citroen Relay at present and have gone for a fixed rear bed also. Eve do a superb small double mattress which I have bought and am building around that. I would agree that making up a bed every night is a pain.
We definitely avoided that. One could slide out the bottom of our French bed without disturbing the other.
Another good reason not to choose to have the cross wise beds
Different view, we wouldn't even consider a fixed bed, waste of space in a 6m van, extra 'room' to keep warm.
Our Inca beds can be ready to sleep in within minutes, less than five, no lifting no assembling, just push a few levers, slide a few sections and all done, easy peasy..
Maybe we have been together too long but he never wakes up when I climb over him either on my way out or back in :) Generally I don't need to get up during the night so a fixed transverse bed is fine for us.
We could use the drop down bed over the dinette if we wanted to which has access both sides.
Before buying a van with a drop down check how far it comes down and if a ladder is required.
I have a fixed bed in my bessacar and its great, I sleep on the cut off side no problems and I am 6ft 3in, only slept in a caravan made up bed but found that uncomfortable
Fixed for me. Easier. Saves time when you’re tired. Very comfortable. Garage underneath.
But if making the bed up and sleeping on cushions makes you happy...............;):LOL:
best thing is to visit a few dealers and look at the options, a friend has an adria with an island bed which is nice but it takes up quite a lot of room
If you do go for a French bed make sure it's a decent length makes getting in and out for the inside person easier. The Hymer we had with one the bed was 7' long.
Layout is of course a personal thing.
but I think - for us- we have the perfect 2 berth layout. Rear lounge (garage underneath), with drop down crossways double bed or longways 2 singles. So one of us can be in bed, the other up and about in the lounge. Van is 6.99 m long.
our first van was twin fixed beds, which was what we thought we wanted, but the small amount of day space that resulted from the fixed beds was more of a compromise than the drop down bed (which at first I didn’t want to have)..
Electric drop down bed every time, best of both worlds in a smaller van. Ours comes down to seat cushion level so don't need a ladder, though it can be lowered part way down.
Reactions: XYL
Layout is personal and depends on your nightly needs, and storage needs
Our van is little larger but we looked ,physically at lots of vans and decided we wanted an ISLAND fixed bed. No disturbing each other in the middle of the night. Lots of storage under it
So I would suggest you find a big dealer (not necessarily the one you will buy from) and jump on hundreds of different beds and work out if that layout suits you
We find most of the French beds too small and many of the drop down beds too weight restrictive particularly those which are motorised. Until recently we'd always made the bed up on our two previous vans, one a PVC the 2nd a coachbuilt. without hardship and the lounge bed in the Tracker EKS was very comfy and huge, nearly 7 ft long and easily 6ft wide and the huge overcab lockers easily held 6 pillows and two super kingsize duvets, 4.5 tog over cushions & 10.5 over us.
With the Pegaso we are certainly enjoying the convenience of the drop down bed which pivots above the cab seats leaving the lounge free to use, it's the size of a standard domestic double bed and has a weight of 250kg. It does require some ladder use but isn't particularly high and me being 20 stone and having rheumatoid arthritis still find it easy to use.
There are pros and cons to both. We have single beds that we have to make up. we opted for that for a few reasons, not least that we both have to get up couple of times a night (sometimes more) and don't want to wake each other up. More importantly, we both have different heat tolerances. I like the heat and feel the cold. the superior officer is the reverse. So we please ourselves with regards to duvets etc. Also, when really hot, say like in Greece last year, being close to someone else sweltering isn't conducive to sweet moods!
mak
Hi there, this sounds a good model for us, can you tell me what can you now have, thanks Sally
Rear lounge all the way. Ours makes up to a king size bed either direction in minutes. Or, if you prefer, two singles. As for lounging of an evening, perfect, lie down, sit up whatever your preference. Once the bed is made up we can make up a small front "dinette" if we wish. We have a large enough through garage under the rear lounge so I don't need any more space. And, who wants to constantly spend time in a cramped tiny upright seating dinette area looking at the waste of space that is a fixed bed. Just saying like. Good luck with your choice (y)
it’s a Hymer Duomobile 534. they also made a bigger one called the 634, which is even nicer but more than 1m longer as well as being a touch wider (the 534 is 2.2 m wide compared with many MH which are 2.36.) If you want any more info just send me a pm ??
Fixed rear bed for us as well and we're in a 5.4m PVC
Went the front lounge, make up the bed every night to start with because we thought we needed lounging space but making the bed every night was a faff and as the one who sleeps on the left and the one who has to get up at night, it turned into a game of "shuffle bodies" every night - Mark moved forward so I could get past him, both dogs had to be moved onto the bed, the dog beds had to be pushed up to the back doors, I used the loo, and then everything went into reverse. We had that van just 3 months before I said enough is enough!
We now have a smaller fixed transverse bed with lots of storage space underneath, I'm on the inside the van edge and Mark sleeps up to the doors. We have the captains chairs to relax in, Mark usually watches films down that end when relaxing in the evenings and I'm like Puddleduck with sitting on the bed, I lean back to the washroom wall with my feet toward the back doors, I can crochet, read, listen to music; I'm tucked away round the corner and the dogs might be with me or with Mark.
The bonus is being able to leave the bed made up during the day, it serves as a useful storage space for soft things like the dinette seat (used to be a dog bed but Mark has managed to find a way to fix the bed to the back wall of the dinette now so the seat is taken off for travelling), slippers etc; not forgetting sleeping on a proper mattress.
It doesn't make any difference to us whether in the UK or abroad, and in fact since we've owned the current one we've been away a few times in the UK and just 4 nights in France.
I think it really does depend on how you spend your "in-van" leisure time plus the amount of storage space needed because the settee we had in the first van only had room for the bedding and a needed bed base cushion whereas our current van has masses of storage under the bed for everything we need and more!
Upvote 1
We have to make the beds up in our Eldiss 115, and we sleep better in that than we do at home. However we have decided our next motorhome will have fixed beds.
Fixed French bed.
Well there you go you obviously did not try the Autotrail Apache 634U The Lounge is an excellent shape,length,and very comfortable with a panoramic view.
Very quick and easy to turn into very comfortable singles or kingsize double.
The big problem with most of the Euro builds is not having the ability to Lounge in the very upright seating of the dinette.
Yes but you have Aguti or ISRI captians seats which are the most comfortable in the house.
Also they don't do water ingress as standard like UK built vans.
