If you have a refillable system in your van such as Gaslow or Gasit you can fill up with Autogas but not simple cylinders such as Calor.Thanks for the info. Jollyroger - What do you mean "only if you know how". I assumed ignorantly that with the adapters one could use lpg found in petrol stations
If I am absolutely honest as I neared the time I needed to fill our Gaslow bottles I dreaded it, silly isn't it. It was easy, just follow the instructions on the pump. There is a minimum fill on most pumps, I forget the amount, but not much. Don't wait till empty, you'll be fine as you are. Yes it is recommended to close valves before filling. If like me after the first fill it's just as routine as Derv or petrol. I downloaded an app from www.filllpg.co.uk it's free and quite useful. Enjoy your travels.We have not had our motorhome very long and we have the Gaslow refillable LPG system, but we have not tried refilling it as yet. One bottle remains untouched whilst the other is looking like its about a quarter full. As we are heading to France for an extended stay very soon I would have liked to have had a 'go' at filling here in UK before I had to mess about doing it with adaptors (which I have) in France. So can anyone confirm (as there seems to be mixed views), is it best to have bottle valve closed and is it ok to fill it before it's showing completely empty? Also I have no idea how much it takes to fill a bottle so just wondering if there is anything at the stations that says you have to draw a minimum amount?
Er, no, currently I have 2 x 13kg returnable calor gas bottles. I wanted to know if you can refill these. If not what I will need for an extended trip to Sweden/Norway.
I've read in several threads that it is possible to get Propane Gas bottles refilled in Sweden, Norway, Denmark & Netherlands. Do you have to provide the adapters or do the gas stations have them?
proper freezer gloves too, not wooly gloves, kitchen gloves or garden gloves. when liquid propane escapes and turns to gas it expands to 200 times the volume and instantly freezes anything it touches. it will burn flesh to the bone within seconds. it is very nasty stuff to be playing with if you dont know exactly what you are doing. even if you do know, accidents happen. ask @Snowbird who got a nasty burn a while backJust to add ... when refilling Gasit/Gaslow type cylinders please, please wear gloves ... if the gas gets anywhere near you it will give you 'cold' burns which are very nasty.
It's not particularly difficult. Once you've done it a couple of times you'll be fine. Actually, it's easier using the French fitting than the UK one - if you are OK here, you'll find it a doddle in France.before I had to mess about doing it with adaptors (which I have) in France
That is very true, why on earth we don't have the French type here I just don't know.It's not particularly difficult. Once you've done it a couple of times you'll be fine. Actually, it's easier using the French fitting than the UK one - if you are OK here, you'll find it a doddle in France.
And I am fuming - right now we are on Calor so I go to local shop, swap a 6kg Calor and get charged £22.
Thats £22 for 12l isn't it - nearly £2 a litre.
It was daylight and I was robbed.
PS... Just looked up a price on www. 6kg = £21.80 but 13kg = £29.68. So a massive
"service fee" is in there.
