- Dec 20, 2013
- 102
- 23
- Autocruise Starlet 2
- started in 1985 been in and out serious 2010
i.ve just bought a 2006 rapido 986m and as part of the deal they had some one fit a solar panel which does not seem to work. On the Scheiber panel there are flashing signs of a charging battery with a bar above it, plus a symbol like a stair also flashing.but the battery is not getting current and is showing 12.6.I checked the cable from the panel that is fed into the pre wired circuit in the wardrobe and that is connected into a set of wire 4 wires on a block next to the fuse box under the bed. 2 from the panel showing 20.5 volts the other 2 for taking the current to the battery.Yesterday i fitted a a charge controller to these cables and it appears to be charging, but nothing has changed on the panel.They also for some reason fitted what appears to be a split charger to the connections to the battery no1 and battery no2 terminal in the main fuse box which seems rather strange i.ve disconnected it but nothing changes . i.ve tried to get info from Brownhills@ Newark ( not the seller) but no joy they are working flat out . Can any one help me with this, bearing in mind i.m not very technically minded, but have in the past had several motorhomes and fitted panels /inverters etc, It is the panel that is worrying part, i.ve tried to contact the seller who is part of a large operation down south but their lines are always busy ,so before i email them i would see what the members can advise. thanks
