Rapido i1090 2023 cbe control panel power button goes red on start up and a caution symbol flashers in the bottom right corner
Derby
coach built
Since 2011
as per the title , my understanding is it could be , waste tank full , fresh water empty , charger not working .
My waste and fresh water both read fine on the display , my battery on hook up reads 14.1vdc again proving the charge system is fine , my only possible answer is with the solar , when I press battery on the controller you get a reading of starter and leisure batteries , but if you press the battery button again I get 0.0A of solar . Ive checked the solar MPPT unit and its showing via bluetooth APP that its working fine , but from what i can see there is only one battery connected to it and i have two , is that a possible ?
Is there any way of telling just why the cbe unit is showing red , is there a secret menu you can pull up that will dig deeper .
When I first power up the panel the on button does go green but only for about 30 seconds then I get red and flashing caution.
I am stumped what to look for so and tips , much appreciated . the batteries are lithium Super B , I think the solar was fitted after market and not by Rapido .
Simon
If it’s the little exclamation mark in a box then it means either something is enabled that it can’t see on the system or somethings something is on the system that shouldn’t be. For example is the toilet tank was turned on but there aren’t any sensors plugged in for it. If it’s displaying solar and it’s an aftermarket solar fit (not cbe regulator) then it may be that, that is causing the error
Found a post yesterday that says there is an extra level of settings if you hold the prog button down while turning on , going to try that and hopefully it is something as simple as turning something off , but i will make a note of all the settings before I play .
