Whilst I have no certainty that is the case. It would make sense to use a M-B compatible item. Do you know which part has actually failed?. ie switch or motor? or?. There are many sources of parts for the base vehicle, and if you can get a part number, you may get a match?. I must confess ours is rarely used.
My Base Vehicle is 906135, and is likely the same as yours.
