- Aug 5, 2017
- 4
- 0
Hi, I’ve a 2014 Swift Esprit based on 2.3L Ducati, 60000 miles. It’s an ex-hire vehicle and I have always had periodically the “brake disc” message and light, even though discs and pads have been replaced on all four wheels. Then this year, the “check glow plugs” message has come up intermittently (in all weathers) as now has the “airbag fault”’, sometimes accompanied by the passenger airbag symbol and the “seatbelt not fastened” (though they are). These latter lights are extinguished when cruise control Is engaged.
All the lights go out as they should as the engine is started but then return at intermittent intervals. On the only occasion when I have driven it in cold weather this winter, the glow plug light flashed as it should and I started the engine when it was extinguished. There is no difficulty in starting, nor smoke.
I’m wondering if it is the instrument panel which I can see has been a problem for others but I have not experienced some of the other reported symptoms, eg lights staying on even when the ignition is off. I am very close to the firm in Hampshire which replaces them but loathe to shell out if that’s not my problem.
Be really grateful for any advice, thank you
