Radio Areial
Kings Lynn
Autotrail Mohican
Since 2013
Hi All,
Anyone know where the radio areial is situated on Fiat Ducato,Autotrail Mohican.
Most Ducatos are on the left windscreen pillar?
Can’t see anything on the left, but have a small black thingy top right stuck to the windscreen,
Just not able to receive radio 2 for very long, after about 10 mins have to keep searching, just wondering if I can fit a different one on the front wing.
Currently parked on the coast in Cornwall and I can't receive a single station in mine :ROFLMAO:
But yes the thingy in the windscreen is probably the aerial if there's not one on the exterior.
You should be able to fit your own onto the wing. Might need a hole cutter and some grommets depending on access.
Thanks HandyAndy, have all the tools, will do that.
Usually in the passengers side wing mirror.
The radio aerial on our 2013 Savannah is in the near-side (UK) rear view mirror. The black squarish box located on the top of the dashboard at bottom left of the windscreen is for the sat nav built into the media centre.
@HandyAndy,
Would you mind repeating that in non silent mode.
I've got a blank screen on your post:unsure:
And in a similar theme, how easy is it to drill the nearside wing and fit an external aerial and thread cable into the 'van.
@HandyAndy,
You've got an ad blocker on (y)
