Propane or Butane
PPVC Autocruise Alto
I'm a newbie
Just asking the informed may I substitute a full butane bottle for a half empty propane bottle as an emergency bottle in the locker for if I run out of LPG in underslung tank during pending French trip just have trauma water / air heater, three way fridge, and hob grill etc.
Yes. Just change the pigtail. Butane does not work well at near freezing temperatures. Make sure you only have one regulator in line.
Yes it will work ok but you need a different connection to the bottle.
You can buy an adaptor hose that you can connect directly from a remote bottle to your onboard LPG fill point. Check out the gaslow or gasit sites for details
You can also connect a French bottle to your fill point also with the same hose but with French adaptor.
Unfortunately most campsites will not allow a free standing cylinder used externally.
Also it’s a high pressure hose connection between the cylinder and the filler point which isn’t a great idea ⚠️
GOK do make the only kit I have seen to connect an external cylinder to a leisure vehicle as set out in the BSEN1949:2021
which campsites are they then?
Definitely the club sites but most bigger sites that know the gas regulations .
Yes you will always find some that either couldn’t care less or haven’t got a clue .
We actually sell the Gaslow version of the connection hose but I warn customers that they may not be able to use it and that they are potentially dangerous.
