Propane Calor Gas Refils? (1 Viewer)
Mar 12, 2012
1,399
1,618
Bridgend, South Wales
Just started!
We use two 6Kg (Orange) Calor gas bottles in our van. To refill locally costs £37, that is swap empty for full.
I notice on eBay there are these:
I'm unsure if it's easy to find refil stations - do you do it yourself - I'm told it's a lot cheaper or is it a no go?
The eBay fitting is circa £30
Any advice/comments?
32,713
66,783
Oh please stop it...
You simply don't understand...
...and the moment I feel the need to have my posts corrected by you is the moment I quit...
JJ :cool:
Read it again ... You missed the ;)
38
31
Birmingahm
Low Profile
This a very dangerous practice as there is no safety mechanism to stop it filling up and therefore explode. DO NOT USE!!!!
189
234
Herne Bay Kent CT65HT
charisma 11 A class.
since 1972
For any requirement to fill an under vehicle LPG storage tank ,,if you are in KENT .The Co-oP service station at Minster on the A299 (Ramsgate Rd ) near Manston airfield ,has pumps 7 & 8 at 89p Ltr,,( 21/7/23 .
meanders
Funster - Life Member
2,704
8,811
Ipswich, Suffolk
I found this on the on the HSE site:
Dangerous Substances and Explosive Atmospheres Regulations 2002
These regulations apply to work situations when a dangerous substance is present and presents a risk to physical safety from, in particular, fire or explosion. For LPG, when the supplier has provided an installation (eg tank) that meets the relevant standards, then the duties that fall on to the user will be to ensure that the necessary conditions under these regulations for ensuring safety are maintained, provide measures to deal with emergencies and make sure their own activities do not adversely affect the storage tank.
While it's primarily concerned with the filling station management, the highlighted part clearly cascades those duties onto the user. A breach is therefor unlawful I believe, but perhaps one of our legally trained people will confirm or otherwise.
The duties of DSEAR include:
  • put control measures in place to either remove those risks or, where this is not possible, control them
  • put controls in place to reduce the effects of any incidents involving dangerous substances
  • prepare plans and procedures to deal with accidents, incidents and emergencies involving dangerous substances
I suspect the 'It's perfectly OK' folks will get zero sympathy from the HSE in the event of an incident as there is no Risk Assessment and therefore no 'controls'. Worryingly, nor will the affected filling station even if they have signs up saying that cylinders cannot be refilled. How long before they all think that it's no longer worth the risk of stocking LPG? That way, all of us who have invested in safe refillable systems will be punished for the misdeeds of the smart a****s! Those remaining LPG sales are likely to only sell to vehicles that need it for motive power.
stevewagner
1,856
4,161
Pevensey Bay
Yonks
Not sure Calor have directly said refilling their cylinders is illegal. They have said it's dangerous and is also against their own t&cs which given that you hire a cylinder rather than own it means the refilled is in breach of contract.
Refilling on a commercial basis by a lpg supplier would be a big problem for that supplier against all sorts of regulations and duties of care. Similarly even an individual refilling a cylinder in the UK, whilst that individual may have limited duty of care, the supplying station has many issues under
Health and Safety at Work Act, the Dangerous Substances and Explosive Atmospheres Regulations, and the Carriage of Dangerous Goods and Use of Transportable Pressure Equipment Regulations.
An old calor article: https://www.calor.co.uk/news-and-vi...refilling-of-lpg-cylinders-at-petrol-stations
Don't forget C.O.S.H.H.
Reactions: hja
Basildog
2,216
3,622
This document and several other industry publications specifically state that the pump operators are deemed to be responsible as they become the filler .
We have always understood from our suppliers that the filling of exchangeable cylinders whilst not illegal would be viewed as unlawful and definitely not in compliance with industry codes of practice etc .
For a few pence we aren’t interested and regularly refuse to serve customers 👍
9,604
32,367
sleights
c class
I have a butane torch I carry in my toolkit, it's refillable from an aerosol, the only instructions are don't smoke and to do it in a well ventilated area. I appreciate it's a lot smaller than a van's setup, but it could still spoil your day if you got it wrong, but it doesn't mention that you will be breaking any law by refilling one gas receptacle from another ?
Presumably it's designed to be diy refilled calor cylinders aren't gasit are hence they can be diy filled. It's not that difficult to understand!
7,346
11,880
West Sussex
Malibu Van 640 LE K
Since 2003
Butane is a very different gas and has a much lower pressure than propane. At room temperature a butane bottle will be at around 30psi but a propane one will be nearer 140psi. They need completely different rules and handling.
255
206
Just looking
If butane so much safer why are most bottles propane? It's not often zero degrees.
Butane is not safer except that the stored pressure is much lower than propane. In fact a butane leak is more destructive than the equivalent propane leak. The calorific value of butane is higher than propane. That is why we burn propane at a slightly higher regulated pressure than butane (14"wg versus 11"wg).
The most dangerous thing I see is keeping a connected and turned on propane underneath the bed without a sealed locker with external sealed drop vents next to a diesel or gas heating system.
Vapourised LPG with available oxygen is approximately 11 times more explosive power than TNT.
Trouble is the Darwin rule for the unsafe users can so easily kill innocent people not involved.
1,000
5,803
Pembrokeshire, UK
Auto-T Expedition 66
What a load of tosh.
Simple mathematics gets you 80% of 22 litres.
If you are incapable that's OK not everyone has the same abilities but don't judge others by your failings.
One additional consideration not previously mentioned is that this relies entirely on the accuracy (or not) of the forecourt LPG Autogas dispenser.
Petrol and diesel pumps are prescribed equipment for the purposes of UK weights and measures legislation. Their design and construction is regulated and their required accuracy is plus or minus 0.5%.
LPG dispensers in contrast are not presecibed equipment in the UK and never have been. There are no regulations pertaining to them and no stated legal tolerances. Many LPG dispensers are also "temperature compensated" (referenced to 15'C) so on a cold day you will actually get a little less than the indicated volume, and on a hot day, a little more.
Additionally, unlike petrol and diesel dispensers, that will be regularly inspected and tested by local authority Trading Standards/ W&M inspectors, no regular independent accuracy testing will have been performed on Autogas dispensers.
If you're using a Gaslow cylinder that automatically cuts off at 80% this is of little concern (other than potentially being over or under charged for the delivery), but if you're relying on the displayed volume on the dispenser to safely fill a standard calor bottle to 80% then pump innacuracies provides yet another variable that can help cause all the slices in the Swiss cheese to line up so the holes perfectly align.
Still feeling so lucky?! :unsure:
255
206
Just looking
I could explain but I have neither time, patience or crayons available!
255
206
Just looking
You do not fill it from either a pressure pump capable of 200 psi. or with propane at 120 psi in the bottle. It is virtually impossible to overfill with butane.hence such devices being legal with butane.
EML
Sep 18, 2018
165
207
Norwich
Transit PVC
15 years
Wow. 10 pages in less than 4 weeks, plus someone who spelt out 'HSE' in full. I knew there was a reason I didn't have gas.
