With a double pole RCD you are safe so it's not so importantIt seems the van has a double poled rcd so do I need the plug etc.
Do you take an earth loop tester away with you? Or just use the test button?I'm not too concerned about so-called reverse polarity - I made up a reverser myself for it anyway - but the lack of an earth is of more interest. That said we're rarely on hookup anyway but we still check as part of our "setting up" process.
The first time you use it, assuming the supply is not reversed, you can go round all the sockets and check that they are all the correct polarity, ie not reversed. Then you can use any socket to test for reverse polarity.I have a three prong polarity tester plug.Am I correct in thinking I can plug this into any 230 socket inthe van when I hook up and it will notify me of any reverse polarity in the supply.
I have a short round blue plug to UK socket adaptor, so with the tester I can directly test the hookup post, useful to see if it is working or not. Also I can test the hookup cable. I've used it several times to sort out a neighbour's mains connection problem.
Many European campsites don't have round blue sockets, but use the local domestic sockets instead. Be aware that the German/Spanish Schuko plug (the '2-pin plug') is reversible, so if the polarity is wrong just flip it over.
