Overhead lamp replacement (1 Viewer)
Vanman
1,689
3,983
Runcorn
Roadscout R PVC
March 2017
Hi - bit of a double question here ... the lamp in the picture has started flickering and I'm not sure how to get the bulb out or where I might buy a replacement. It looks like it's probably spring loaded into the ceilling but I don't want to go forcing it or gouging before I know that's the way!
Thanks!
Jun 24, 2023
9
9
Yeovil, UK
Auto Quest 195
Since 2022
Looks like a usual downlight. If so, try gently pulling the inner circular ring down and the bulb should hang by its wiring.
Local B&Q should stock similar bulbs (if I remember correctly they are G4) ???
TheBig1
17,688
43,768
Not bulbs, those are LED and the driver board has failed. Not all are replaceable and are sealed. They can be fixed with the right tools but many people just replace if you can find them. Held in by metal spring clips
