Timbob1961
- Mar 17, 2021
- 30
- 2
- Matrix Supreme 670
Anyone have a pdf of the Matrix 670 operating manual?
Cheers Tim
if your matrix is std it has an 85ah gel leisure battery. if its in good order and not been abused and... you dont hammer the use of the TV etc then 3 days should be ok on thatI am wondering what is needed so that we have enough power to stay unplugged for 3 days.. Any ideas as to a good solution?
fridge should run on gas, and with 140 watt which is as i have, then 3 days is no issue unless there is no sun and you have the TV on for more than an hour or so each day. your lights are led so small drain.It has a 140w solar panel..
I just thought the fridge consumes a lot and a TV also with lights might not last...
i would guess its gas and mains but probably on mains it will be up to 2KW , then 4 - 6kw on gas / electric. but i am not sure as i dont have the Alde system.Thanks.. Subscribed now
We are due to receive our Supreme 670 SL at the end of the month.
Just trying to get to grips in advance.
Is the Alde heating gas only or also electric on hook up?
The Alde heating runs on both Gas and Electricity - like most motorhomes. Gas brings the heating up to required temperature quickly. You will probably have a heat exchanger as well which warms the van and water in winter as you drive along and allows you to warm the engine before setting off in the morning. Enjoy the Alde - it is gloriously snug.Thanks.. Subscribed now
