Odds and sods
Hampshire
Chausson 640 welcome
Since October 2019
Little fittings required anyone know of a good source
need
a few of the plastic caps for the screws that hold the internal window frames in place
a screw cap for one of the screws on the inside of the freezer (god knows how I lost that )
some of those circular “wall paper” blanks which cover various fittings inside (about 2 cm diameter )
Thanks I’ll take a browse
Those caps for the window frames are horrendously expensive ☹️
For the round finials found at the end of shelves in a fridge that fit in the side walls, (I'm with OP on this, How did it get lost?)
I found an end cap of the same diameter that mimicked the original. I then drilled a hole into the middle (friction fit) to take the shelf end.
The white colour round wallboard sticky things only seem available through the Chausson dealers. I had quite a few replaced by the dealer when they were doing warranty work.
As I can't find any online anywhere, I just got some double sided self adhesive film sheets and use this as a new backing for the round covers that seen to have lost their stickiness (stick the used cover onto the sheet and cut out around with a craft knife).
Did anyone else think that this thread was gonna be about forum members ....???? :rofl:
