This has appeared on my LCD Screen, Everything appears to work okay, it did it whilst on The Tunnel crossing but started fine and went back to normal but it’s just appeared again.
Any ideas?
Any ideas?
Difficult to see Starter Battery Zero as it starts fine and resorted to showing full charge shortly after start up.Saying your starter battery is zero, and your leisure battery is drawing 2.8A.
Has the fuse failed on your split charge side? Is the leisure battery charging when the engine is running?
This is a possibility,this is a new vehicle and has some form of WiFi built into the Battery System that l haven’t yet got my head around.It occurred to me that the Tunnel cut the WiFi signal but it hasn’t rebooted if that makes any sense.Possibly interference from Tunnel electrics or thrown a wobbly due to the pressure wave you get entering the tunnel;.
A few years ago after going through the tunnel in a VW transporter had no indicators, aircon, central locking and electric windows not working. Stopped & phoned UK dealer they had no idea, restarted the engine 15 min later & everything worked.
I get the impression that the reason that maybe 7 people in 10 worry about their electrics is that their sophisticated panels provide far too much information.This has appeared on my LCD Screen, Everything appears to work okay, it did it whilst on The Tunnel crossing but started fine and went back to normal but it’s just appeared again.
Any ideas?
We need to start a petition to ban the unnecessary use of microprocessors.Sometimes I wonder if all this stuff is getting too smart for its own good.
