Note to self......... check batteries!!! (1 Viewer)
Feb 12, 2018
665
5,339
South Yorkshire
Adria Coral 600SL
Since 2017
Thought folk may like to see what can happen when you don’t keep an eye on batteries.
Less than a year old, apparently never checked and dry as a bone...…...
………….when this blew apart huge amounts of flammable hydrogen gas would be present and one spark could mess up your day severely!!!
If a battery is warm to the touch it has a problem, if there is liquid on the top of the battery it has an issue and if it smells of sulphur turn the Charger off ASAP.
:eek::eek::eek:
funflair
18,894
28,988
Guisborough
MORELO palace
since 2012
I think a lot of people assume that batteries are all sealed for life now, but they ain’t (y)
Martin
Jaws
23,762
74,643
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
May I amend that a little ?
Do NOT turn the charger off from inside the van. If the switch sparks, then BOOM!
Unplug the hook up from the post end ( in other words as far from the van as possible )
Open doors and windows until the bad egg smell completely goes.
Only then disconnect the battery(s)
For solar panels, cover the panels or wait until it is dark, all the time venting the motorhome
6,553
7,411
Manchester
A class Hymer
Since the 80s
What kind of charger was it? Were solar panels fitted? Was it a sealed battery or was it the type you can top up? Was it left on hookup long-term?
Nasher
2,094
7,265
Pontardawe
Pug Boxer
Since 2013
A bit of superglue and a few hours connected to one of those smart chargers and they'll be fine
Millcourt
Feb 12, 2018
665
5,339
South Yorkshire
Adria Coral 600SL
Since 2017
Don’t have details, but looks like a wet lead acid type of battery of the need to top-up variety - probably not commonly used in Moho for leisure batteries, but on some for starter. Thought it was just worth making the point that it is a good idea to keep an eye on batteries (whatever the type), rather than assume you can fit and forget.
Millcourt
Feb 12, 2018
665
5,339
South Yorkshire
Adria Coral 600SL
Since 2017
Very sound advice - thanks.
