Carthago ELine 2021. For the first longish trip we can hear a fan like noise from the n/s dash. It stops then starts again even when everything is off and the keys are out. The media button is off and we are parked up. Any thoughts please.
Don't think so with no engine running. Kit relys on additional burn heat through the exhaust which would stop as soon as engine stops.DPF regeneration?
Same on my neighbours Phaeton, when only a few months old it once kept on for over 10 minutes after switching off.DPF regeneration continues for several minutes on my Golf after engine switch off, just sounds as if the cooling fan is running quite fast.
Not the cooling fan, it’s not that loud. It’s very intermittent runs for a while, then stops, even when parked for the night it seems to be on and off. we thought it was linked to the media switch, but it comes on when everything is switched off. im a bit worried about it flattening the engine battery when we are parked. When we park up tonight I will check the discharge on the batteries.Is it the engine cooling fan? They can keep running when ign is off.
