Hi All
After a little advice (I did try to look through previous threads for the answer but no joy).
I have a 2012 Bailey Approach which the manual says has a Whale Smartflow pump.. yesterday when arriving at a festival I filled up with water - Shows as 85% full, was previously on about 10%…. Went to turn on tap to bleed through but nothing happened, pump was running but very quietly compared to normal.. left it be overnight whilst I read up on a few things and this morning have checked and now pump is not even making any noise.. I’ve checked/changed the fuse, no joy! Also looked at manufacturers settings and it is showing a voltage setting of 1.74v which I believe to be a fault, I need to still try recalibrating the water probe as per my investigations but can do this yet as don’t think my neighbours will appreciate swimming in the 85litre I need to dump to follow the calibration process.. Any help appreciated just trying to get ahead of needing to a professional in after the bank holiday!
Sharne x
Sharne x
