You do but it’s the removal of the threat of having to quarantine abroad that will reassure most travellers. Well, me anyway.You still have to do a paid for LFT on day 2, cheaper but not “no tests”
Like you I didn’t mind the cheap French tests. I don’t understand how you think a test would stop you catching it on board a plane or ferry though. Tests don’t stop covid and don’t always pick it up.Never minded the cheap tests in France, just the expensive and hard to get test here. Always felt the test before returning woud stop catching it on board ferry or plane. The one here was a waste of time as you had already been checked before returning??????????
There are quite a few that seem to think testing will stop covid. I’ve never understood it.
The Day 2 test is now Lateral Flow not the PCR so the cheaper one.Hello bobnick, i dont think you have to do pcr before getting on plane back to uk anymore, but you have to do pcr when you get home (2days) but no quarantine …. I think
If all around you on ferry or aircraft have had negative test results it must reduce the chance of catching it onboard.
You cannot use the free NHS LFT kits you have to pay to have a LFT done. Still cheaper than the PCR but you still have to find somewhere legit to get the tests doneGood news for us travellers. No more expensive tests to take on our return to the UK.
Colyboy
pampam was nearly correct.When we return to UK from UAE on 16th Jan what test do we do after arriving.
We have to do a PCR before we get on the plane. But after landing Manchester bit confused as to what we have to do.
EDIT. We are double and booster stabbed.
That fact tells us all exactly what the testing is all about. Money, that’s what. The LFT is the same test whether paid for or not. The result of the test is the same whether paid for or not. So it’s not about the test but about the money.You cannot use the free NHS LFT kits you have to pay to have a LFT done. Still cheaper than the PCR but you still have to find somewhere legit to get the tests done
Really sensible .... notGood news for us travellers. No more expensive tests to take on our return to the UK.
Colyboy
Might change again by March 18thGood news for us travellers. No more expensive tests to take on our return to the UK.
Colyboy
If all on the ferry had taken the test and had the pass before getting on the ferry, then the chances of spread during the passage would be reducedLike you I didn’t mind the cheap French tests. I don’t understand how you think a test would stop you catching it on board a plane or ferry though. Tests don’t stop covid and don’t always pick it up.
If and it's a big If, tests pick up all positives which they haven't so far. If the tests did pick up all positive cases there would be no need for PCR tests.If all on the ferry had taken the test and had the pass before getting on the ferry, then the chances of spread during the passage would be reduced
now doneUp here in the kingdom of North Korea we are still waiting on our dictator accepting a 4 nation approach to international travel testing
Simplytestme.co.ukSomeone mentioned a company that provides the RFT at £12.
Must be a different thread.
Could anyone remind me the name of this company please.
And are they Gov approved.?
Not really if people have taken the test 2 days before travel, and some people could retest an hour later and become positive. Planes/airports and ferries are far more likely to spread it than people out in the sun on holiday so the 2 day post test is far more important.If all around you on ferry or aircraft have had negative test results it must reduce the chance of catching it onboard.
The only gteed method is isolate for 5 days then test, then isolate until departure.For everyone.otherwise a waste of time.If all on the ferry had taken the test and had the pass before getting on the ferry, then the chances of spread during the passage would be reduced
