No hot water đź’§ can anyone help (2 Viewers)
Debbie65
9
5
Wakefield
Autotrail
2 years
We are due to go away tomorrow but can’t seem to get any hot water
We have an Autotrail eks tracker
My hubby’s mobile number is 07852 968675
We would really appreciate any help from anyone
Debbie
SandraL
1,373
985
Somerset
Hymer b694sl
Does any water come out of hot tap?
Does the boiler light on gas? Can you feel heat from the boiler gas flue ?
5,427
21,688
Cumbria
Have you shut the frost drain valve and bled ALL the air out of the pipes ?
1,547
1,264
West Sussex
Carthago Chic A clas
Since 1990
Have you checked the Truma dump valve is closed. If it's open.....it's probably already dumped all the water from the fresh water tank.
8,698
45,053
Worcestershire
Bailey Adamo 75-4t
March 2018
As above really.
Boiler drain valve closed?
Tap and water system drain valve closed?
Have you bled the hot and cold water systems?
Is there any error code on the control panel?
Good luck
4,931
18,760
Bexley Kent
Given up Motorhoming
May 2019
When did you have it working properly last. And what did you do when you locked it down?
8,698
45,053
Worcestershire
Bailey Adamo 75-4t
March 2018
I think there have been threads about questions asked then no feedback I guess if the OP does not come back at least the thread may help others.
Al-Di
3,063
28,946
prestwich
Eura Mobil A Class
since 2013
probably embarrassed(no reason to be) when found the dump was open,
JockandRita
11,477
150,381
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
There's nothing wrong in eating humble pie now and then, which just goes to show that we are all human. ;)
Cheers,
Jock. ;)
