no heat from furnace (2 Viewers)
john and carole
12
brierfield lancs
american rv
just started
need some advice please. when we switch the blown air heating on the fan starts up but the gas doesnt ignite.where do we start to look and if we cant spot anything does anyone know of somewere in Lancs for help.PS complete novices with this rv thingy:RollEyes:
Sundowners
3,289
3,571
Suffolk/Central Portugal
37 years
First thing to look at, your batteries must have plenty of charge. We've had the same problem. As ours was a bit long in the tooth, we eventually replaced ours with a new furnace as we are now fulltiming in ours and we didn't want an 'iffy' one over last winter. It cost us $660.00 bought direct from the States.
'Damondunc' on here knows a thing or two about them and repairs them, so it might be an idea to pm him.
Nigel and Pamala
2,337
10,147
Have a furnace troubleshooting guide .. too big for attachments, I will upload to the download section..
Jim
john and carole
john and carole
12
brierfield lancs
american rv
just started
Thanks guys ,batteries have plenty of charge so will download furnace troubleshooting and take it from there and hope its nothing to serious:thumb:
2,337
10,147
Mine is often troublesome at the onset of winter, but after running it's usually fine ..
Good luck, persevere, if it's been idle for a while it may take several attempts to get it lit.. the gas line may be empty, dampness is also a problem if it's been laid up, try spraying the board and connectors with some WD 40 .. make sure there are no spiders webs in the burner and air intake..
Look inside the van, make sure the air intake isn't blocked, ours is under the sofa and Jan once put a blanket in and blocked it ..
Jim
GEOFFs125
43
Salisbury, Wilts
C Class RV
Have a look at the trouble shooting guide posted by ScotJimland.
I used something similar to diagnose the fault on my furnace. My furnace would ignite and blow hot air for a few seconds, then blow cold air for a few seconds, re-ignite to blow hot air for a few seconds then blow cold air for the remainder of the cycle until it was switched off.
I replaced the PCB, supplied by Linda at Stateside, now it ignites first time everytime :thumb:
Good luck
Geoff
chatter
3,689
937
cheshire
5th wheel
We had trouble with the furnace in our 5ver last year had to get a new strikey thing and have that put in, ours kept clicking when trying to light but failing to ignite the gas
PeteH
6,853
9,030
East Riding of Yorkshire
Rapido, 999M.
18+yrs plus 25+Towing
Furnace Probs
The Suburban Furnace relies on a "Sail Switch" which requires that the fan is running AND MOVING SUFFICIANT AIR before it will allow ignition. IF this is "stuck" it may attempt to start but not fire up.?
any use?
pete
