New Discs & Pads - Help
Wissel
Horncastle, UK
Van Conversion
Since 2006
Hey all, I'm trying to order new discs and pads (front and rear) and not getting anywhere. There are so many different types/weights/etc, I'm just going around in circles and could do with a bit of direction.
What I'd like is Brembo front and rear discs and pads, with the highest payload rating I can fit. I need the 280mm, 118pdc, 28mm.
I "think" I have the discs sorted:
Front: Brembo 09.A235.20 - Broken Link Removed
Rear: Brembo 08.8094.30 - Broken Link Removed
Then I try to find the right pads and... well, no idea 😐
I just want the best stopping power that will fit my van, with the best payload rating as I may need to uprate.
Van is a 2010 Boxer l3h2 2.2hdi 88kw (120).
I'd like to get it all ordered today so I can have it fitted next week. Help....
I am no mechanic, but if you increase pads or discs for better stopping will they foul on anything underneath ?
Hi David, if you increase the disc / brake size make sure your wheels fit without fouling the wheels/brake calipers
Never had a problem with the standard brakes on any of my vans.
Cheers guys.
I already have 280mm, 28mm discs, so not changing anything it that respect.
But there is a huge selection of discs/pads in the same size and I'd like to fit the best I can.
Have you looked at what GSF have got to offer, they stock some Brembo Discs & Pads for a 2010 Peugeot Boxer I don't know if they have the versions that you want.
Note that they have a discount offer on at present Code MID60
Take a photo of your vin plate and always quote that or send them a copy.
