Surfstar
- Jul 20, 2019
- 26
- 49
- Burstner - A class
- Since 2008
Hi,
We bought this a month ago for our year travels but have decided its unlikely we will be using it as we aren't planing to stay anywhere for long term and could do with the space. Therefore we are selling it! We are currently in South or France, heading for Spain so could deliver in person depending where in Spain you are. Possible courier option, will need to check the price and logistics. If you are heading south, you could also collect it from us if you are passing.
Price - £500 with delivery.
Price to buy an equivalent - £1200+
It has never been used and only unboxed to check all the bits where there. Here is the blurb:
Best suited to taller van based based on Fiat Ducato, Peugeot Boxer etc or coach-built motorhomes with a fixing height 240 to 280cm
Our Opinion:-
The Motor Fiesta Air Pro is designed for motorhomes with a fixing height of up to 280cm. Featuring their Weathershield Pro Polyester fabric. This gives the look and feel of a more traditional awning fabric and is well suited to C-Class and A-Class Motorhomes, to give a more luxury feel and look to the awning.
The Motor Fiesta Air Pro has limited fixing options as they are designed to attach to an awning rail or Wind-Out Awning (Fiamma/Omnistor) and has a 6mm awning bead and the option of straps or guy-lines over the roof to attach to the vehicle. To attach to a Wind out awning to you would need a Fiamma/Omnistor driveaway kit.
The Motor Fiesta Air Pro also features Kampa's Single inflation system. So you only inflate the awning at one position, for quick and easy pitching.
Lots of windows and fly mesh doors allow plenty of light and good ventilation without the bugs coming into the awning. These is the option of a 2 berth bedroom annexe and sun canopy.
In our opinion this awning is best suited to taller van based based on Fiat Ducato, Peugeot Boxer etc or coach-built motorhomes with a fixing height 240 to 280cm
What the manufacturer says:-
Free-standing drive-away motorhome awning. Hugely versatile, offering access through both front and side doors. The Fiesta Motor Air Pro also offers the facility to add an annexe either side, as well as an additional sun canopy on the front. Quick and easy to erect, with a one point inflation system, although each tube can be isolated if needed.
Key Features:
Inflatable - one point inflation system
Each tube can be isolated via isolation valves
Free-standing drive-away awning
"Feel the difference" double coated 300D Weathershield Oxford Polyester
Flame retardant and UV Stabilised
A massive 6000mm hydrostatic head
Seams hot air taped - for maximum weatherproofing
Zip out front and side panels with door
Adjustable height rear tunnel to suit a range of vehicles
Crystal clear windows with blinds - for a great view out
No-see-um mesh fly-screen on side doors - keeps out even the smallest bugs
6mm Kador (beading) fitted
Height: Designed to fit camper-vans and motorhomes with a rail/roof height up to 280cm
Taped seams
Width 350cm
Depth 275cm
Pack Size 85 x 45 x45cm
Weight 23kg
Our Opinion:-
Key Features:
Taped seams
Width 350cm
Depth 275cm
Weight 23kg
