Got a Thetford fridge N100 the interior light doesn’t work is there a fuse for the light and where would it be everything else is ok Rapido A class tested the bulb ok no power to it
As your Thetford N100 has an power board I expect it is a SES model (A) and on the wiring diagram the reed switch appears to go to the display board which then goes to the power board which supplies the light. Although not on the diagram the power board seems to have fuses on it but I do not know what they are for www.arelectronics.co.uk repair these boards (which show fuses on their examples) and may be able to advise you.
