Multimeter
  • Thread starter Thread starter 69473
  • Start date Start date
6
69473
Can anyone suggest a good quality multimeter to add to my tool kit.
Many thanks
Take your pick. I chose a £10 one from Screwfix after recommendations from funsters. Works for my very limited knowledge. Some of the meters are shockingly priced sorry about the pun😂
For day to day basic stuff a cheap is fine. I had 2 at work one cost hundreds and the other cost one penny on Ebay, the cheap one got a lot more use
What budget?
What do you intend to do with it?
Something like this for under a tenner will be adequate for basic checks (and more sophisticated stuff if you have the experience).
DIGIFLEX Volt Testing Digital Multimeter Voltmeter Ammeter AC DC Meter OHM for DIY: Amazon.co.uk: DIY & Tools
I find it amusing that a lot of multimeters have a test facility for measuring the hFE of transistors. How many people would know what a hFE measurement represents and of those that do know, how many would still want to test a transistor.
Many manufacturers buy in a (often the same) proprietary microchip (and housing, display, dial, knob, leads) that provides all those functions, whether needed or not.
What budget?
Pretty basic stuff I guess if it's his/her first meter.
I had an Avo 8 years ago. It was an old school massive thing. I went to Maplin (remember them?) and bought a cheap Chinese jobby and it does the job for home electrics and the mh.
I used my multimeter a few days ago and looked at that facility on it, made me smile😁.
To PNP or NPN that is the q
uestion...
I do. :xlaugh:
I replaced a basic voltmeter with one of these as I wanted to measure amps without disconnecting cables, very happy with it but be careful to get one that is AC/DC as a lot are AC only.
Fluke is all I use, I’ve got a couple of them.
The one in the van I have had since 1987 and it’s never missed a beat, it’s calibrated every year and never failed.
But the cost of calibration is 10 times the cost of a basic multimeter and the accuracy of the cheap ones are so good these days.
Fluke
I am planning to acquire a MM in anticipation of the delivery of our new MH. As I know virtually zero about this kind of stuff I visited the Fluke website to find quite a lot of options.
Would the following (https://www.fluke.com/en-gb/product/electrical-testing/digital-multimeters/fluke-114) be ok for Motorhomes requirements? Apparently it doesn't measure current. Do I need that facility?
I would suggest a cheaper model ( as suggested in earlier post) costing approx £10 would be suitable.
And you've got to watch out for the self-identifying ones. Could be AC passing as DC or vice versa. 😃
Something like the above or the Screwfix one, are great for most of us DIYers (I even use the diode tester)
So cheap, I have one for my workshop & one in the moho
I think one of them I got for less than seven quid delivered (from a uk supplier - but made in China)
Exactly.
The accuracy on my ten quid ones is very good and any slight error reading is close enough for all m/h needs.
My needs are mostly as a circuit continuity tester (wiring, fuses, bulbs) or to check whether my original 12 volts have dropped somewhere along the line to 11, or whether my batteries are charging from the alternator or other charging device.
I have the UT210E, it doesn't have the temperature or frequency measurement and only 100 amp but a tenner cheaper.
If I had known about the 204 I would have probably gone for that just for the temperature measurement.
IMO the DC clamp meter is an essential bit of kit when fault finding on a Motorhome.
Yup, I use flukes every day at work and have one for home use too.
But, I highly recommend the Uni-t clamp meter for motor home use, the ability to check DC current easily makes it some much user friendly
Another vote for the Uni-t meter. Very easy to check current, using the clamp feature.
Amazon product ASIN B07CNGJXFJ
I have used Fluke for over 30 years but my employer now provide Sealey MM20 units as standard issue for field engineers. Not near the Fluke for build quality but plenty accurate enough for 12v vehicle systems
Having tried one I think they are amazing value for about £16 and if lost or damaged are not causing drama with replacement cost.
Last time I bought a multimeter I was amazed to find it didn't have a 'beep' function for continuity.
I find the beep really helpful, so went in search if a model that had it.
Turns out many models don't beep, but I'd strongly recommend making sure whatever you buy has it, especially for fault finding on your own when the other half is reluctant to come out in the cold :-)
Also, my latest model has a strong magnet on the strap. Really useful for:
1) hanging from whatever metal object your working on so your hands can be freed for holding the probes.
2) Latching onto all the small parts of your socket set and emptying boxes of screws all over the floor.
Are you sure about that.. :unsure::ROFLMAO:
I made a fool of myself by taking my meter back and demanding a replacement because the buzzer on the continuity didn't work..
I felt rather foolish when it was pointed out to me there was nothing wrong with it..even then I didnt believe the bloke.. and it wasn't until a random customer coming into the shop convinced me it must be my hearing..:eek:..
Needless to say I left rather embarrassed..but still have that meter..
The old ones used to have a bell..which I can still hear..its just the electronic buzzer frequency I'm totally deaf to:rolleyes:
Andy..
Unless your an electrical expert don't waste money buying an all singing and dancing unit. I just replaced mine with a multimeter from I think it was Aldi but it may have been Lidl cost something like £12.99. Does everything you are ever likely to need and the accuracy is spot on.
