Little help please dual mppt controllers, do any of them allow the leisure and vehicle battery to be different types of battery, i want to change the leisure battery to a lithium battery thx Chris
Note: This feature currently requires accessing the site using the built-in Safari browser.
That's worrying Lenny as I have the same set up. What problems were they.I would normally recommend the Votronic controller but a few people have had problems with them with Lithium.
Exactly the same as the Votronic.You may find having a battery master will be simpler (takes surplus from leisure and trickles to engine battery).
If I recall correctly there's been a couple of instances when they stop charging and have to be reset.That's worrying Lenny as I have the same set up. What problems were they.
Thanks. My 350 MPT has been OK in the 6 months since it was installed. But, just in case, what is involved in resetting?If I recall correctly there's been a couple of instances when they stop charging and have to be reset.
Our Votronic 250 Duo has been fine though, fitted it in 2018![]()
I had the Voltronic duo and had intermittent problems with charging.That's worrying Lenny as I have the same set up. What problems were they.
That seems to be the usual problem with them on Lithium (are you on Lithium) our problems started after they had been fitted and working fine for a few months, they were tested in germany and declared to be all OK and of course they had never heard of this problem beforeI had the Voltronic duo and had intermittent problems with charging.
Occasionally there would be no charge to the batteries and a clicking noise could be heard from the controller.
I would have to pull the fitted fuse and then re insert it to get the unit to reset.
I contacted 12v planet where I purchased it six months before and they gave me a returns label and sent it back for testing.Took about seven days.
I had a full refund from them and have since changed to Victron and a battery master.
They did suggest using a different profile but I said that I wanted to use the profile that they recommended for our batteries and the battery manufacturer supported, on later models they changed the instructions in the box and took out the specific reference to our batteries and a recommended profile.Martin funflair wasnt the problem just on one setting, other lithium settings were OK but not suitable for your batteries?
My Votronic 350 is set via the DIP switches on the "LiFePo 14.6" profile, which was what KS agreed was the nearest one to optimal for their batteries. That provided 14.6v full charging and 13.6v for trickle/storage charging, which were both at the top of KS's recommended ranges. The "14.4 profile" would have been better for full charging, but the trickle/storage charge was 13.8v, which was outside KS's 13.6v maximum.Martin funflair wasnt the problem just on one setting, other lithium settings were OK but not suitable for your batteries?
Yes, I did go over to lithium .That seems to be the usual problem with them on Lithium (are you on Lithium) our problems started after they had been fitted and working fine for a few months, they were tested in germany and declared to be all OK and of course they had never heard of this problem beforeeventually after sending lots of evidence to 12V Planet they agreed to a refund even though Votronic continued to deny any problem existed, I then purchased Victron off 12v Planet and all was fine, I have to say that 12V planet were very supportive.
And to answer your question threewheels yes in theory and as Lenny says you would set the duo controller for the main habitation batteries and then just let it trickle charge the starter, our van came with Buttner PWM duo controller charging Lithium and trickle charging the LA starter battery, they seemed to work fine which was funny really as Buttner were producing the Votronic controllers for them then (I think it was that way round).
I set the switch to Lifepo profile.My Votronic 350 is set via the DIP switches on the "LiFePo 14.6" profile, which was what KS agreed was the nearest one to optimal for their batteries. That provided 14.6v full charging and 13.6v for trickle/storage charging, which were both at the top of KS's recommended ranges. The "14.4 profile" would have been better for full charging, but the trickle/storage charge was 13.8v, which was outside KS's 13.6v maximum.
I would be interested to know what profiles funflair and grasscutter were using.
There are 5 LiFePo profiles to choose from. Can you remember which one you chose please.I set the switch to Lifepo profile.
I would have been on the 14.4v - 13.8v.My Votronic 350 is set via the DIP switches on the "LiFePo 14.6" profile, which was what KS agreed was the nearest one to optimal for their batteries. That provided 14.6v full charging and 13.6v for trickle/storage charging, which were both at the top of KS's recommended ranges. The "14.4 profile" would have been better for full charging, but the trickle/storage charge was 13.8v, which was outside KS's 13.6v maximum.
I don't think grasscutter is a 430.I think the problems reported have only occured with the 450 model, or is my mind doing what it does.
Are your batteries not inside the van? not that cold tonight surely.Having looked at the Votronic charging graph I am a bit more worried. Just noticed that below zero temperature they have a "reduced charge current" but the voltages stay the same. Surely they should stop charging altogether when the temperature gets to zero? Looks like we are in for low temperatures tonight so I think I will switch of the solar.
And LiFePO4 ?Guess what mine is?![]()
No, I bought the votronic because it had the option to add lithium at a later date!And LiFePO4 ?
They are indeed. But no heating on. It is parked at the front of the house and permanently plugged in to the mains, so the new Victron mains charger can keep the batteries topped up and it will turn off when it drops to 5 degrees. Switching off the solar now is easy and I won't need to remember to do it when the weather does really get cold.Are your batteries not inside the van? not that cold tonight surely.
No, I bought the votronic because it had the option to add lithium at a later date!Anyhow it’s not fitted as yet so I’ve still got the epever still on powering the two 80ah Carthago gels. It seems the only real way to go is a wall of blue
