Big Nult
i have a 2014 Chausson best of 10 and don't Knowhow to connect the appliances to gas,the manual isn't very clearin their instructions on how to connect and ignite fridge etc.
Thanks Martin my gas bottle is about empty and I read somewhere if the gas pressure was too low it wouldn't work properly so I'll connect to full gas bottle.do I need to ignite for the fridge ?When you say "connect to gas" I guess you mean switch them on as they should already be connected, you will have a gas isolation valve for each appliance so these will need turning so the handle is inline with the pipework, your gas bottle needs to be on as well of course.
Martin
Martin
The fridge.... once set to gas... will or should... self ignite...
As for low gas in bottle... that shouldn't make a difference... unless of course it's empty...
Ps... you should be able to google the user manual for your fridge... if your Moho "user guide" is unclear... as some fridges are auto changeover types and some are manual... e.g whether they run on gas, 12v or 240v...
Also there may be a button next to your regulator in your gas locker... that may require pressing - if you've had the bottle disconnected...
I have a best of 510 with the same fridge I believe.
Once you've changed the bottle check hob for gas flow, hold selector button on fridge until it flashes then with arrows move onto gas flame symbol. While gas symbol flashing green, select temp of fridge with arrows that move the green dots up/down. Then push selector button again which will go solid green & you should hear gas ignition.
Sounds complicated but Not in practice.
If no joy, check valve open on manifold in small cupboard below fridge.
I had Gaslow installed to avoid the bottle changing!
Rob
