Motorhome auto electrician in Worcs/Glos?
Worcestershire
Bailey Adamo 75-4t
March 2018
The top rear tail lamp has gone out. I think it might be a duff wire somewhere as it did work intermittently so maybe not a duff LED.
I have traced the wire to a real mess of a connection box under the rear of the van but cannot be sure which wire it is that I need to investigate.
Also I see that the wire to one of the rear parking sensors has come adrift. Time for a professional I think.
Can anyone recommend somewhere in the Worcs/Gos area that is good?
Many thanks
Adria Matrix M/H
Have you access to the base vehicle wiring diag...??
The box you describe is where the converter cconnects the various circuts from the standard vehicle wiring to their wiring..and their colour scheme.. ive wasted time trying to pick up the wrong coloured wire in a loom because of this change from vehicle to converter wiring..
If you can be bothered you should still be able to identify the wire you want with a meter... but if its only the one unit /bulb that is effected id be concenrtating my efforts on the connections to that unit...and establishing it is in fact working wirh a rigged up alternative supply...
..and if youve gone to that trouble you might as well reconnect your parking sensor wire (y):LOL:
Andy..
Have booked it into the dealer I bought it off. I may have another go before that but I'm a bit worried about messing up another connection in the process.
Thanks for the advice.
