Motor scooter ramp to garage needed....
Milton Keynes, UK
Burstner Lyseo 727G
3 years 30,000 miles UK and Europe.. Campsites and off Grid.
Any recommendations for ramp to get my scooter into the garage?
Finding the cheapest version of this one has done us well, folds in half, takes 5 seconds to set up.
<Broken link removed>
Another vote for a folding ramp. Excellent bits of kit. I use them for taking 1000cc motorcycles in and out of my van with no issues.
Yes as above BUT you want to get some angle aluminium, cut two lengths the same as the ramp is wide, then drill and bolt them on to the end to make a channel. This channel then drops over the lip of the garage stopping it from slipping forwards or backwards as you load / unload your awesome steed! (y)
I load a big 4 wheel mobility scooter in the garage using telescopic aluminium ramps. If you look on ebay there are often pairs of London black cab ramps. they double telescope down to about 800mm so easy to store and you can sell the spare one on
Many of the motorcycle ramps are more suited for loading into the rear of a Transit type vehicle with a flat loading area.
My garage door opening has a vertical lip which is 40mm above the general garage floor level. I've chosen to "locally" raise the garage floor by 40mm within the general footprint of the scooter. This allows easier extraction of the scooter, without having to negotiate the 40mm high lip.
My preferred ramp has a hook at one end which is secured over the lip. This is what I use:
