Mk6 Transit
Eggs
Suffolk
can anyone help?, firstly this isn't my mo/ho it's my work van.
I got out of the van earlier and locked the doors and the indicators flashed as they should, but the near side indicator, front, and rear stayed illuminated, not flashing, just on. No key in the ignition, idicator stalk was in the off position, any ideas?
I've had a few transits and not had this. Does it do it every time? You could try disconnecting the battery for a minute to reset the electrics
No, it did it the once, but since then on occasion the near side indicator didn't flash when indicating, it stayed static. I was advised that it could be a problem with the indicator relay, stalk, or hazard warning switch. I swapped the relay (cheapest option first) and neither faults have happened since... touches wood.
